1-inch lifters in an A460 block ?
Last edited by JBR-3 on September 20th 2020, 1:07 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: 1-inch lifters in an A460 block ?
First, I am by no means an expert on this and I am sure others like Lem, Phillip, Randy, etc. can answer this better than me. But just from my own observation with Ford's blueprint of the factory block, the inboard side of the lifter boss would be getting pretty thin bored to 1.125" and could be prone to failing with high lift cams and high spring pressures. Did Ford beef that area up with the A460 blocks, I don't know. Now, if it's an Eliminator Premier or Ultra block based on photos I have seen, it may be entirely feasible. Like I said, I'm not expert, maybe the Pros will chime in.
Last edited by JBR-3 on September 20th 2020, 1:08 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
You're in the ballpark, it's closer to .200" in thickness. Blueprint shows a radius of .640" from the centerline of the lifter bore to the outside of the casting. of coarse each block is going to be a little different due to core shift during the manufacturing process.
» Cometic MLS head gaskets
» Differences between stock type block and the a460 block?
» distributer block hole is too small on an A460 block
» Roller lifters, factory block
» small block roller lifters in a 460
