A96 block cylinder length
QtrWarrior
fastbarry
i am looking to put a big inch aluminum A-head motor together and may have found an A96 block with 4.600" bores and a 10.3" deck to use. i would like to use a 4.75" crank but i come up with different opinions on using them in standard deck height blocks. do these blocks have the same trouble supporting the piston at the bottom of the stroke as the iron blocks when using a 4.75" arm or are they any better or worse?
i have no experience with big ford alum blocks and have never actually had my hands on one. i do not know how the cyl length compares to any of the iron stuff
this motor is being built to go in a sandrail to replace a turboed chevy LS. My 2 main goals are broad strong torque curve (where 4.75" > 4.5" ) and reliability (where 4.5" > 4.75").
i already have the top end package, motorsport a460 heads and motorsport single 4 intake.
i would appreciate any insight and advice you guys might have.
thank you,
barry
thank you,
barry
fastbarry- Posts : 72
Re: A96 block cylinder length
Are you sure a 4.750 will fit in the block ??
I have an A91 and a 4.750 won't fit without ALOT of grinding inside the crankcase....
So we went with a 4.625 and still had to grind some clearance..
QtrWarrior- Posts : 2693
No I am not sure it will fit. I don't have a block or crank in my possession yet.
If you buy from C and C Motorsports, they can supply you with a block and whole shortblock assembly that has been cnc'd for clearance. They can even assemble it all for you, just throw your top end on it and complete it.
Its more money, yes, but its also less hassle and it speeds up the project!!
BBFTorino- Posts : 982
^^^^^ Pretty cool they offer it that way.
68formalGT- Posts : 862
BBFTorino wrote:If you buy from C and C Motorsports, they can supply you with a block and whole shortblock assembly that has been cnc'd for clearance. They can even assemble it all for you, just throw your top end on it and complete it.
That's because Carrol's shop is a speed shop that sells parts, has a machine shop in the basement, and a nice dyno room.
kjett- Posts : 1169
kjett wrote:BBFTorino wrote:If you buy from C and C Motorsports, they can supply you with a block and whole shortblock assembly that has been cnc'd for clearance. They can even assemble it all for you, just throw your top end on it and complete it.
And he's going to make "Thor" heads!!
thanks guys i think this get me closer in choosing a direction with the build.
» 540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
» What cylinder head is the best for a stock block?
» block thickness (cylinder walls)
» valve to cylinder bore/block clearance
» Cylinder Head to Block Dowel Pins
