Tube/Pipe Bending?
Tube/Pipe Bending?
Does anybody on here have the capability to bend 1" Schedule 40 aluminum pipe with a 90 degree bend?
Re: Tube/Pipe Bending?
TBH I don't know if a manual drag/draw through bender (like say a JD2) could bend aluminum tubing/pipe without damaging it (collapsing, galling, snapping, etc). What alloy aluminum the pipe/tubing is made also probably makes a difference too.
Also is it sized as "tubing" (1" OD), or sized as "pipe" (1" ID)
DILLIGASDAVE- Posts : 2262
It's a piece for my boat, so I would prefer a marine grade like 5086 and it has to be sized as pipe, 1" Schedule 40 with OD of 1.315" and ID of 1.049".
Yes I do it a rachet bender for conduit we have at work we bend aluminum conduit with. It is a Greenlee brand if I remember Tuesday I get the model we even bend stainless steel sch 20 pipe with it
Doug I went to greenlee site here is the one we have you might fine a electrical contractor around you that could bend it for you.
https://www.greenleestore.com/products/greenlee-1800-mechanical-bender-for-1-2-3-4-1-imc-and-rigid-conduit?utm_medium=cpc&utm_source=googlepla&variant=15440388931&gclid=CNON5Lvw2dQCFQwYgQodA7wLiw
What about buying an 90° aluminum elbow? You're a pretty good welder.
Curt- Posts : 2787
69F100 wrote:Doug I went to greenlee site here is the one we have you might fine a electrical contractor around you that could bend it for you.
Thanks for the info but I not to sure a conduit bender will work. I think conduit has different diameters than pipe or tubing.
Curt wrote:What about buying an 90° aluminum elbow? You're a pretty good welder.
I have considered that option too but I think I may have found a place online that can do the job, just waiting to hear back from them.
I will check tomorrow and see what 1'' aluminum conduit od is
I found a business down in Florida called Custom Pipe Design that is going to make the piece for me at very reasonable price. They specialize in making T Tops, Tuna Towers, Radar Arch's, etc. for the marine industry and some major boat manufacturers. Very nice people to deal with and no job is to small, owner told me he will have it made today and shipped. Cool!
» Breaking Rocker studs and bending push rods
» X-Pipe orientation
» Pipe stands
» X-pipe diameter
» Air cleaner plumbing, is 6" pipe enough for a 545?
» Pipe stands
» X-pipe diameter
