Throttle cable 71 Torino Mount on intake.
I switched intakes on my Torino and my new intake doesn't have a place for the factory bracket to mount for the carb.. Has anyone found a mount that can be used with the factory cable?? This is for a dommy carb. I would like to stay with the factory cable set up.
Thanks Tore
Thanks Tore
Tore- Posts : 862
Re: Throttle cable 71 Torino Mount on intake.
On my 70 SCJ Torino the bracket used the rear 2 carb mounting bolts. When I switched to an 850 cfm Holley carb the bracket hit the accelerator pump, so I cut it in half and then bent it so it hit the carb base and wouldn't twist. Unfortunately these brackets on ebay aren't cheap but that's what I did to keep my throttle cable from the factory.
jeffgfg- Posts : 338
i have used this style
https://www.summitracing.com/oh/parts/csi-620b/overview/
the ones for the gm cable can be modified to use
wayne
wayne
wayney- Posts : 187
That's just the one I ordered!!!wayney wrote:i have used this style
wayne
Tore- Posts : 862
» Throttle Cable and Kickdown Cable Questions
» Throttle cable?
» Throttle cable cut to fit???
» need help with throttle cable
» What throttle cable
» Throttle cable?
