1" carb spacer
1" carb spacer
I have some room now for a 1" carb spacer. I have a stock motorsport "victor" intake with ported A429's. The local speed shop has a 1" open all star piece in stock. Is there much to be gained with a Jomar power cone over an open spacer?
BigRigTech- Posts : 763
Re: 1" carb spacer
The only way you'll really know is to test and see. I've dyno'd all sorts of intake/spacer combinations and I've never found a consensus. Some that I expected to make a big difference didn't, and the opposite...I've seen 12hp from one on a motor that I didn't expect much. Just depends on the combination.BigRigTech wrote:I have some room now for a 1" carb spacer. I have a stock motorsport "victor" intake with ported A429's. The local speed shop has a 1" open all star piece in stock. Is there much to be gained with a Jomar power cone over an open spacer?
Scott Foxwell- Posts : 419
Re: 1" carb spacer
Lots of trial and error here but on the BBF strokers I've messed with they liked the Jomar piece better than nothing, better that open and better a four hole. The trial is maybe the power cone thing wants a 1" open under it. Keep in mind that the gain may be only 8 or 9 hp but that's a good deal for only using a 1/2" wrench.BigRigTech wrote:I have some room now for a 1" carb spacer. I have a stock motorsport "victor" intake with ported A429's. The local speed shop has a 1" open all star piece in stock. Is there much to be gained with a Jomar power cone over an open spacer?
Re: 1" carb spacer
That's pretty much what I was thinking Lem, if the space is there I might as well put in a spacer to see what happens. I might even have room for 2. I'm crossing the stripe at 7000 or so if that makes any difference.
» 4500 Carb Spacer's
» Carb Spacer - Airflow Test
» Carb Spacer & Gasket ?
» Modified the carb spacer...
» 4500 carb spacer
» 4500 carb spacer
