eagle rods in 545
eagle rods in 545
i have a used engine with eagle rods in it.it has some miles on it but bearings look good.it was not a race engine,low rpm street truck.bolts are arp l-19.i am upgrading engine for bracket racer in 68 mustang,with a bigger cam,victor intake and 1050 dominator.
should i replace the bolts with new ones,or just retorque them.?
hbstang- Posts : 339
Re: eagle rods in 545
There is no reason why you can't reuse the rod bolts. L-19 bolts are strong but can be weakened by corrosion. If you see any corrosion then replace them. That material is prone to corrosion. The 2000 material from ARP is overlooked as being not as capable but it is not likely to corrode.
Dave De- Posts : 788
Dan,
I have a set of SPS CARR bolts if you want to change bolts. Let me know . Remember I'm right around the corner.
gt350hr- Posts : 662
bolts
hey randy,good to here from you.I only pulled a few bolts out and so far they look really good.no corrosion.engine was well taken care of.
Look them over very closely, make sure they don't show any traces of twist, stretch, flaking, etc.
BBFTorino- Posts : 982
» 460 builds
» 6.700 eagle rods (7)
» Eagle 6.605 rods
» Eagle Rods
» WTB Scat or Eagle 6.605 Connecting Rods
» Eagle 6.605 rods
» Eagle Rods
