560 C460 Build/Dyno UPDATE
+6
66prostreetfairlane
Copperhead
Hardy
dtimmer
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Just finished and going into my 2006 mustang tube chassis. There is more left in it with a little more work, but I'm pretty happy with it so far.
Eliminator Premier Block
Wiseco 4.635 pistons compression @ 15:1
Callies 4.150 crankshaft
GRP aluminum 7.090" rods
Total seal rings
C460 heads worked on pretty good. 2.450 x 1.88 valves, Intakes go around 520 cfm
60mm camshaft 8/2 swap 286/308 @ .050" 118 LSA (installed @ 114) .963/.936 lift with the current 1.7 ratio rockers
Jesel Cam drive with Jesel belt drive distributor
.937 crower lifters
1/2 diameter .200 wall Trend Performance pushrods
T&D 1.7 ratio rockers
PAC 1258 springs
VED sheetmetal tunnel ram
APD 1250 cfm carbs
Barnes 6-stage drysump
Aerospace vacuum pump
Total seal rings
.937 crower lifters
PAC 1258 springs
APD 1250 cfm carbs
Re: 560 C460 Build/Dyno UPDATE
Wow! Awesome build
Hardy- Posts : 107
Mike R- Posts : 1381
That should slay quite a few Chevy's!!
BBFTorino- Posts : 984
Damn,.....
9000+ RPM,....
That's NUTS
Copperhead- Posts : 492
Is the displacement dictated by rules/weight breaks? Where will the car be running?
Hardy- Posts : 107
No, class rules did not dictate the cubic inch. I had the heads, some used pistons, and a crankshaft. I need an engine until my 640" billet headed deal is done.
My home tracks are Mid-Michigan Motorplex and US131 MSP. But I will be running some OSCA races and Milan Outlaw 632 with this. And whatever else I can find that it fits in, including some fast brackets.
Curt- Posts : 2787
That is one awesome engine!!!
glenevans- Posts : 315
dtimmer wrote:No, class rules did not dictate the cubic inch. I had the heads, some used pistons, and a crankshaft. I need an engine until my 640" billet headed deal is done.
Don Losito heads?
68formalGT- Posts : 864
dtimmer wrote:Hell no lol. My billets. Visner Engine Development.
https://www.429-460.com/t19392-new-bbf-billet-heads
Those are the ones. I've made a few changes to them over the years, but same basic design. The new engine will be 640", valve sizes in the head are 2.650" x 1.850" will have just over 1.100" lift. Looking to make 1500-1550hp with it.
I'm actually going to be putting this 560" deal back on the dyno here in a few weeks. A few minor changes to it, id like to be closer to the 1300hp mark with it. I think I can get close, but not sure if I can cross that mark without a piston change.
What bore and stroke on the 640"?
That's a big piston! What block are you going to use? 4.9" BS?
That's awesome, I thought you might build it on an aluminum block.
Could you put that head on a 4.650" bore with those valve sizes?
Yes, it will fit on as small as 4.625" any smaller than that, the intake valve needs to go down to 2.600"
Can I borrow this motor to get my Torino into the low 9's just once??
Changed rocker arms, springs, and cam timing. Now I'm fairly certain the carbs are too small.
Page 1 of 2 • 1, 2
» Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
» 525 A460 New Dyno results
» 557 P-51 BUILD AND DYNO RESULTS
» Neat 545 Build w/EZ Efi and dyno results
» 557-A429 Bracket Build-Dyno Results
Page 1 of 2
