1" carb spacer
1" carb spacer Empty 1" carb spacer
Post  BigRigTech August 8th 2017, 3:07 pm
I have some room now for a 1" carb spacer. I have a stock motorsport "victor" intake with ported A429's. The local speed shop has a 1" open all star piece in stock. Is there much to be gained with a Jomar power cone over an open spacer?
BigRigTech
BigRigTech
1" carb spacer Empty Re: 1" carb spacer
Post  Scott Foxwell August 8th 2017, 3:38 pm
BigRigTech wrote:I have some room now for a 1" carb spacer. I have a stock motorsport "victor" intake with ported A429's. The local speed shop has a 1" open all star piece in stock. Is there much to be gained with a Jomar power cone over an open spacer?
The only way you'll really know is to test and see. I've dyno'd all sorts of intake/spacer combinations and I've never found a consensus. Some that I expected to make a big difference didn't, and the opposite...I've seen 12hp from one on a motor that I didn't expect much. Just depends on the combination.
Post  Lem Evans August 8th 2017, 6:23 pm
Lots of trial and error here but on the BBF strokers I've messed with they liked the Jomar piece better than nothing, better that open and better a four hole. The trial is maybe the power cone thing wants a 1" open under it. Keep in mind that the gain may be only 8 or 9 hp but that's a good deal for only using a 1/2" wrench. Smile
Post  BigRigTech August 8th 2017, 6:34 pm
That's pretty much what I was thinking Lem, if the space is there I might as well put in a spacer to see what happens. I might even have room for 2. I'm crossing the stripe at 7000 or so if that makes any difference.
BigRigTech
BigRigTech
