Mustang II or Ranger front suspension ?
rbro460
JBR-3
1971 Mustang project. I would be grafting the new suspension onto the car, probably also getting new front frame rails.
The ranger suspension looks like it might be more heavy duty than the Mustang II, plus would have bigger brakes.
Any advice on the Ranger suspension ? 1998 and on.
Ultimate goal is that I don't want any crossmembers under the engine, I want to use a full length oil pan. And no strut suspensions.
JBR-3- Posts : 266
Re: Mustang II or Ranger front suspension ?
JBR-3 wrote:1971 Mustang project. I would be grafting the new suspension onto the car, probably also getting new front frame rails.
Are you going to use motor plates with this application??
rbro460- Posts : 102
I don't think I'll go with motor plates.
JBR-3- Posts : 266
I googled to see if they were the same as the explorer but could not find an answer. I have an 04 Explorer and they handle like crap and have wicked bump steer. I could not imagine ever wanting to go race car fast in it that's for sure.
jasonf- BBF CONTRIBUTOR
I ran the ranger frontend under my 2000 ranger with the 460 and the 552 never had a problem only reason taking it out was to give more room and less weight on the frontend the ranger front clip is heavy for sure
Thanks Gents.
69F100, did you set the firewall back ?
JBR-3- Posts : 266
Yes moved it back to the door opening when I set the engine I put the front of the engine center of the front spindles
Why are you so against struts?
On the strut deal, I'm going to use fairly wide front wheels and tires, not a typical skinny drag/pro street build.
JBR-3- Posts : 266
JBR-3 wrote:On the strut deal, I'm going to use fairly wide front wheels and tires, not a typical skinny drag/pro street build.
So a fox or sn95 style front?
As far as the MII, you can buy just about any configuration you want. Everybody makes everything for a II crossmember...... thru the coil, coil overs, bags, extended tube control arms, standard-lowered spindles and every brake configuration up to 13" rotors, stabilizer bars, Every wheel bolt pattern. etc, etc. I believe there is a weld in with reinforcements for every Mustang any early year gen 1 thru all fox's. It is akin to saying 350/350!
Colt Macara- Posts : 132
» Need advice on 70 mustang front suspension with BBF.
» Complete Mustang II Front Suspension
» Front suspension ?
» front suspension for 70 mustang fast back
» 1970 Mustang AJE front suspension conversion.
