What causes flare on the 1-2 shift in c6?
ED468
rocketpony
my c6 tranny is revving up between the 1-2 shift, what cause this? Is it jus band or clutches too?
rocketpony- Posts : 120
Re: What causes flare on the 1-2 shift in c6?
bands wore
Frank Merkl- Posts : 1524
Do you know the history on this ? fresh build ? Old ? Could be as mentioned band worn or could be the moulded servo piston rock hard and leaking
Gregaust- Posts : 613
actually should never flair on the 1-2 shift as the sprag is holding until the band takes hold
How can the sprag (what Ford called an overuning clutch) hold 2nd gear? The band must be applied for 2nd or. 1st and 2nd would both be on at the same time
DanH- Posts : 1081
the sprag holds until the band stops the direct drum ,them it overruns
Till it stops the drum. The band can can let the rpm flare up for a few reasons
DanH- Posts : 1081
rocketpony wrote:my c6 tranny is revving up between the 1-2 shift, what cause this? Is it jus band or clutches too?
Something in the system which controls the second speed band or the band itself.
The cause is too much power, or atleast more power than the shift can hold. Happens pretty often in my stuff. You can firm up that 1-2 shift by stacking pennies in the accumulator as well as some spacers in the modulator valve. This will firm up the 2 shift a lot, so long as the servois holding and the band is good. If the slipping was measurable at all, that band probably burned and a snap band might be in order.
colorado ford man- Posts : 33
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» C6 2-3 flare
» C6 with 2nd to 3rd flare
» C6 Won't roll backwards in neutral-Band too Tight?
» C6 Second Gear Flare Won't Go Away
» C6 2-3 flare
