water outlet
water outlet
HIYA FOLKS I know this is a old topic but maybe some new answers. I kinda figured that my water neck might give some problems , and it has. Trying to put dist. in I found that it wouldn't go down all the way cause of it hitting the water neck. Has anyone ever modifyed one? I've read the old post's on here and haven't seen anything.If I have to I'll notch it and weld a inset piece in it. Any info would help before I cut. THANKS
charlie 1- Posts : 13
Re: water outlet
not sure what intake/ distributor combo you are running but I use a 96-97 efi 460 outlet from a truck .it has a flat cast in from the factory .
thanks, wayne
thanks, wayne
wayney- Posts : 187
outlet
I am running a stealth manifold and a hei dist. If the dist. was 1/4 taller from block to base it would be fine. Might have to make one. Have made a lot of stuff for this. Will check out the one u mentioned .thanks
Re: water outlet
Check and see if any of these will work for you. Made by Four Seasons (down side made by a Chinese Company and available on Summit Racing) Part# 85185, 84860, & 84859.
» 16an water neck for bbf
» Turbo outlet tube ? 6.0 PSD
» Nitrous outlet Stinger plate
» Water in oil???
» 460 Water Pump Crossover Tube that goes in the Intake to the Water Pump?
» Water in oil???
