Priming oil pump on a short block
Just finished a 429 short block.
I thinking I could spin the oil pump and check the oil pressure, just insert the lifters and prime?
Would this work and if so what do I look for? Or do I need to install heads, pushrods and rockers and then prime?
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Priming oil pump on a short block
TEST wont be real till you install heads,and all the valve train, and set the valves
BOSS 429- Posts : 2367
» short oil pump
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» Is this a long or short water pump?
» 490 short block
» 532 inch combo for street? pump gas with 5200-5500 shift point.??? any suggestions?
» 490 short block
