4.6 crank in a factory block?
Hardy
I'm looking into going bigger with my 507 over the winter. I know a 557 would be the more popular choice, but with Ohio Crankshaft offering their 4.6 stroke forged crank, I was wondering if
A) that will fit in my D1VE block? And
B) are there any other reasons not do it? Nothing to gain over the typical 4.5?
Also, with my ultimate goal being to run 9.2x or faster in a 3500# leaf sprung 72 Mach 1 (guessing I'll need about 900 hp at least), are the BT CJ heads I am currently using with raised Ford exhaust a viable option with porting? Or would selling them and upgrading to P51's be cheaper and easier in the long run?
I appreciate any help I can get guys. Thanks in advance
Hardy- Posts : 107
Re: 4.6 crank in a factory block?
It may need a touch of clearancing with H beams but not much. D1VE blocks are short skirted so you will be pulling the pin way out the bottom. It would be nice to get a 6.8" rod but the compression height will be real short at 1.200"
I'd be looking for a deeper skirted block at least a D9TE.
I'm almost 3300 pounds and running 9.0's in 1700 ft air with P-51's and a mild roller with a 4.50 stroke x 4.530 bore.
I wish I had a 4.30 crank.
Dave De- Posts : 792
Good info. Thanks for the reply. We do have another block that my dad picked up a few years back. I'll have to check what that one is. I'm thinking in a factory block using stock port location heads there really wouldn't be any reason to go bigger than a 4.5 stroke anyway.
Your cars running pretty darn good! Sounds like your power plant would be about enough for what I'm tying to get. Hopefully with a 532 or 557 and a little more rpm I can get similar results.
Hardy- Posts : 107
Why is that?
windsor- Posts : 1167
Hardy wrote:Good info. Thanks for the reply. We do have another block that my dad picked up a few years back. I'll have to check what that one is. I'm thinking in a factory block using stock port location heads there really wouldn't be any reason to go bigger than a 4.5 stroke anyway.
Thanks for the compliment. I think it should be running 8.80's and it probably will with a few small changes next year.
Why is that?
At 580 cubes its a little big for P-51's in their current form. If it had a 4.3 crank the parts would match well. Future plans are to step on the heads, intake manifold, and some drive line changes to make this combination work better. I'd be happy running 8.90's in bad air but its just a bracket racer anyway always chasing. Its been a while since I've been chased.
It's been 9.08 at 148 with a full exhaust. 9.03 with open headers. The 4" exhaust weighs 70 pounds.
Makes sense, I'm debating myself whether to go 4.3 or 4.5 for my DragWeek deal (leaning towards the latter with A460's and a 4.65" bore).
I did a 4.6 Ohio crank this year it made 900hp at 6700 on a pump/avgas blend. Use a d9te block and the longest rod you can. 6.8 at least. I prefer a Molnar 6.85 dodge rod machined to fit. The long rod helps the piston stay up the bore. everything cleared with no grinding except the pistons needed a little touch. here is the one I did in the proven builds thread https://www.429-460.com/t26283-566-a460-head
Racerrick- Posts : 7
^ yes, that’s a nice build
Racerrick wrote:I did a 4.6 Ohio crank this year it made 900hp at 6700 on a pump/avgas blend. Use a d9te block and the longest rod you can. 6.8 at least. I prefer a Molnar 6.85 dodge rod machined to fit. The long rod helps the piston stay up the bore. everything cleared with no grinding except the pistons needed a little touch. here is the one I did in the proven builds thread https://www.429-460.com/t26283-566-a460-head
Yes, I remember seeing that one. Great job on your build!
Hardy- Posts : 107
4.600 stroke in stock block
Did 4.600 stroke in stock block recently zero clearancing.
lilcarlie- Posts : 3
lilcarlie wrote:Did 4.600 stroke in stock block recently zero clearancing.
Which block was that?
Why is that?
Why not send the heads off and have them worked on?
68formalGT- Posts : 864
Why is that?
I will be making these heads flow to match the cubes in the bottom end before next spring if ll goes well. The car went 9.03 this morning in 1,000 ft air with the exhaust on. Not bad for old backup slicks, blowing thru the converter in second gear, and two smashed primary header tubes. I need to update more than the heads but that's the worst of it.
Back to the 4.6 crank.
I wouldnt do it unless the heads were the newer TFS A heads.
