Valve spring delima !
I feel like I have talked with several reputable engine builders about this particular situation that has me confused!
I have a small block stroked to a 408 13.0:1 compression.
8000 RPM
Cam is a solid roller with
Lift
Intake .688 exhausted .672
Duration @.050
Intake 276 exhaust 284
Lobe seperation 107
Installed @103
Some more info :
Lobe lift
Intake .4300 exhaust .4200
Timing events intake op 35 cl 61 Â exhaust op 73 cl 31
1.6 rocker ratio
Spring psi that cam company wants me to run is
250+ on seat
780 open
Installed @ 1.90
What do you guys suggest ?
Thanks Whitefield
8000 RPM
Lift
Duration @.050
Lobe seperation 107
Installed @103
Some more info :
Lobe lift
1.6 rocker ratio
250+ on seat
780 open
Installed @ 1.90
Thanks Whitefield
Last edited by whitefield on October 18th 2017, 1:36 pm; edited 2 times in total (Reason for editing : Add more info !)
whitefield- Posts : 2243
Re: Valve spring delima !
whitefield wrote:I feel like I have talked with several reputable engine builders about this particular situation that has me confused!
8000 RPM
Lift
Intake .694 exhausted .698
Duration @.050
Intake 268 exhaust 274
Lobe seperation 107
Installed @103
250+ on seat
780 open
Installed @ 1.90
Thanks Whitefield
I don't know much but that seems way to high on the open pressure to me!!!
Mark Miller- Posts : 1861
A lot of it depends on the ramp rates. Some solid rollers will whack a valve open faster than the speed of light!!
Lobes like that need big spring pressures. Other lobes are more forgiving and you can back the pressures off a bit.
Are you experiencing valve float or broken springs??
BBFTorino- Posts : 982
you building a race car or a street car?
What's the installed height? Lobe lift? Rocker ratio? Spring rate?
Who's lobes and what numbers?
And just for the record those are not super big springs.
But I do suggest listening to the cam manufacture over soliciting online random suggestions.
dfree383 wrote:you building a race car or a street car?
It is a race car
Bullet racing cam
Installed 1.900
1.6 shaft mounted rocker arms
3/8 .080 push rods
Spring rate 644lbs./in.
I will get the rest of the info in a few minutes.
I agree with your last statement, but there are a lot of good experienced people on this forum. I am not on any other forums anymore this one is home. Thanks
P.s. The other reason I was confused is I was getting two different answers from two different people from bullet.
Personally ... I would use the PAC-1244 valve springs.
The Lunati #74744 is the same spring.
I added some more info about cam and changed some things I had wrong in first post.
PAC-1225 was the spring they recommended. Thanks Whitefield
whitefield wrote:I added some more info about cam and changed some things I had wrong in first post.
A PAC-1225 has 314 pounds force at 1.900" installed height.
765 pounds force at 1.200" height.
A PAC-1244 has 227 pounds force at 1.900" installed height
747 pounds force at 1.200" height.
whitefield wrote:dfree383 wrote:you building a race car or a street car?
It is a race car
Bullet racing cam
Installed 1.900
3/8 .080 push rods
Either Spring Randy suggested would work IMO.
» Affect of valve spring install height on spring rating..
» Valve spring cup
» Valve spring cup
» Valve spring
» Valve spring ?
» Valve spring cup
» Valve spring cup
» Valve spring
» Valve spring ?
