header hp loss ? from hooker long tubes to D&D mid lengths any idea what to expect
5pointslow
im waiting on my engine diaper to come in from dre Nov 10th and then i going to try to get engine in car
i have hooker super comps using solid mounts , tubular kmember ........(im going to try first )
if i run into any crazy issues fitment , i noticed D&D sells a 2 inch primary mid length header that will work with my jw bell as well
My question is any idea hp loss going from hooker long tubes to mids both 2 inch primarys and yes i know this is vague motor made 649 with hookers
5pointslow- Posts : 1394
Re: header hp loss ? from hooker long tubes to D&D mid lengths any idea what to expect
With an exhaust system you probably won't see much difference
dfree383 wrote:With an exhaust system you probably won't see much difference
just running bullet mufflers and turndowns
going to try the hookers first but will see how much issues i will have fitment and collector height ( i hope they work out) , have 25inch front runners may need to go to taller tire as well.
worst case i order the midlengths up from D&D
thanks for input
Subbed. I'm curious to see input on this topic as well. Has anyone tested this on a track or dyno?
Edit: OP, what cid are you running?
nickpohlaandp- Posts : 157
nickpohlaandp wrote:Subbed. I'm curious to see input on this topic as well. Has anyone tested this on a track or dyno?
472ci (.060 over)
I'm pretty sure zbob has D&D mid length's on his Zephyr box top, maybe he'll chime in on this or send him a pm
Mike R- Posts : 1381
hmm, you rang mike? ya I do.
..... with eldebrock heads. I have a tubular kmember with swap mounts. I utilize the front slots on the kmember. have about 1 1/2 spacers between it and the frame.
.....I did have to grind the block plate and a little more material on the starter bulge on my c6 belhousing. also double d steering shaft clearance was on the order of a 1/16.
....not sure of hp loss. I have absolutely no traction with street tires, blow all three gears off with 3.55 gears. with small drag radials all the way through first gear is up in smoke too. bob
zbob- Posts : 269
well they aren't any shorter then fender exit headers and they are the new rage
351crules- Posts : 10
» [b]514 Keith Craft BBF (Part Out)[/b]
» header damage how much power loss if any ? kinked . *please take a look *
» What can I EXPECT TO PAY ?
» Power Gain or Loss or Break Even Shorty Headers vs. Smaller Long Tube
» D.O.V.E. vale lengths
