New F4 Procharger at the PRI show
Post  jones on Mon Dec 14, 2009 3:25 pm
This has to be a joke, I couldn't imagine a drag car with this much weight out infront of the front wheels. Now I could see where the truck and tractor pullers would love it!
sam92lx wrote:When I came over to the Procharger booth first thing Thursday morning, I thought this was some kind of cruel joke. A supercharger the size of a trash can attached to the front of a big block Chevy, and it is nearly half the size of the engine itself. This is the new Procharger F4 supercharger and it even requires a minimum of 900 naturally aspirated horsepower to make it work.
This blower is a gear drive only type system that is designed to make 3200+ horsepower, 45 psi, and flow over a hurricane-like 5400 cfm. The gear drive system on this blower is the same unit you will find on the F3. This is a limited production piece (obviously) and is designed for extreme drag racing. We heard that this blower was going to be tested soon, but no name was released. The one hint we had was “A previous NMCA Pro Street Champion”, which immediately leads us to think Mark Mickie.
You can barely see the engine behind the blower!!
"It's hard to believe that engine builders and racers are looking for even higher power levels and increased blower efficiencies than the F-3 models already deliver," says Jim Summers, Motorsports Director at ProCharger. "The F-3 has proven capable of 2,000 horsepower on pump gas and 3,000 horsepower on an engine specifically designed for use with a supercharger and running alcohol fuels."
Make sure your cat isn’t walking buy when you fire it for the first time, it might just suck it in.
NEW ProCharger F-4 Supercharger: specifications
Volute Diameter: 16-inches
Max HP: 3,200+ HP
Base NA HP: 900-1,400 HP
Max Flow: 5,400 CFM
Max Boost: 45 PSI
Inlet Hose Dia: 7-inches
Inducer Dia: 6.32-inches
Exducer Dia: 8.89-inches
Outlet Hose Dia: 5-inches
Outlet ID: 4.26-inches
Max Impeller RPM: 55,000 RPM
Internal Step-Up Ratio: 5.63:1
Reverse Rotation Available: Yes
Self-Contained: Yes
Oil Capacity: 4 ounces (larger capacity available for extended run-time applications)
For comparison: ProCharger F-3R-139 Supercharger specifications:
Volute Diameter: 12-inches
Max HP: 2,700+ HP
Base NA HP: 700-1,000 HP
Max Flow: 4,000 CFM
Max Boost: 45 PSI
Inlet Hose Dia: 6-inches
Inducer Dia: 5.47-inches
Exducer Dia: 7.20-inches
Outlet Hose Dia: 4-inches
Outlet ID: 3.59-inches
Max Impeller RPM: 62,500 RPM
Self-Contained: Yes
jones
Re: New F4 Procharger at the PRI show
Post  69F100 on Mon Dec 14, 2009 9:18 pm
with that thing it would be like the girl standing in front of the car and the guy revs it up and it suckes her in all you would have to do is be walking by with someone reving the motor and be sucked in but by the looks of that thing
Post  richter69 on Mon Dec 14, 2009 9:42 pm
So I guess the thing hangs in front of the bumper????? Wonder how much that thing weighs?????
Post  bruno on Tue Dec 15, 2009 9:43 am
i heard the just the charger weighs 75 lbs ....... time to cut the firewall out Cool
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  jones on Tue Dec 15, 2009 10:29 am
I would have guessed closer to 100lbs. Seriously though, how are you suppose to fit that thing in a NMRA, NMCA, ORSCA car when the rules require the firewall in the factory location. I can only see this going in a ADRL Pro-mod or something.
jones
Post  D. Sea on Tue Dec 15, 2009 12:19 pm
OMG that thing is HUGE! I agree Josh, I don't see how that could fit in a door car...
D. Sea
Post  Northwest outlaw on Tue Dec 15, 2009 1:14 pm
Thats a f2 the new one is only a little bigger tons of room Twisted Evil
Northwest outlaw
Post  richter69 on Tue Dec 15, 2009 1:18 pm
jones wrote:I would have guessed closer to 100lbs. Seriously though, how are you suppose to fit that thing in a NMRA, NMCA, ORSCA car when the rules require the firewall in the factory location. I can only see this going in a ADRL Pro-mod or something.
smallblock...............
Post  jones on Tue Dec 15, 2009 2:36 pm
That would have to be one serious small block to move over 5,000cfm! I can see it now, a F4 Procharger with a Boss 302 attached to it. You would mount the F4 to the chassis and hang the 302 off of the supercharger!
jones
Post  badnotch on Sun Jan 24, 2010 9:47 am
WITH THE F-4 AND GEAR CHARGER YOU ARE TALKING 140 POUNDS AND THE CHARGER TAKES 500 HP TO RUN cheers
badnotch
View user profile http://www.gnlmotorsports.com
Post  RTCTTFMF! on Mon Jan 25, 2010 12:24 pm
We are on the list to get one and test it on a "BIG" Ford engine. At the time of the show Procharger didn't spin it yet and get real world numbers. As soon as something happens I'll let you guys know. Funny thing is alot of people talk about all of the weight and its size-yet if it's more efficient than a roots type "heatmaker" it did its job.
Did you ever lift a roots blower!! affraid
RTCTTFMF!
Post  jones on Mon Jan 25, 2010 12:34 pm
I would figure since the roots blower is on top of the engine most folks don't think about the weight. Where the first thing that grabs your attention with the F4 and Gear drive is how much further foward the weight is. I know weight isn't everything because I have heard that some cars have to add weight in the front. Let us know when you get more info!
jones
