SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More Empty SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More
Post  Paul Kane on November 6th 2017, 9:52 pm
UPDATED SPRING CLEANOUT 2019 - Garage cleanout, I will be uploading pics here & there as they become available:
Please call directly for details (number at bottom of post)
________________________________
Ported D0VE heads, just finished, oversize 2.25”/1.74” stainless valves, bronze guides, snap-on valve stem seals, 3-angle valve job, polished combustion chambers, resurfaced, dual springs for flat tappet cam, hardened locks, aftermarket retainers, ready to bolt on and run. These D0VE heads are capable of supporting at least 600 hp in a proper engine combo with a flat tappet cam and more than that with a roller cam. $1400. Personal delivery in California is possible.
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More D0vehe10
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More D0vehe11
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More D0vehe12
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More D0vehe13
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More D0vehe14
4.200” forged steel crankshaft, Bryant/Ford Racing forging, std-std, turn the rods 0.010" and it's good to go. $700
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 4200_010
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 4200_011
(Pistons sold)
(Pan sold)
Ford F700 Commercial 429 Truck Pan, never hurt, straight and solid, just needs blast & paint, pickup included, nice $150
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More F700_010
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More F700_012
Fully rebuilt Ford 9-inch differential, professionally rebuilt by Rearend Specialties in Santa Clara, CA. Originally removed from a running and driving 1981 Ford F-250 truck, the specs are as follows:
* Ford 9-inch Rear End from 1981 F-250
* Set up for leaf springs
* Measures 65.25" from axle flange-to-axle flange
* New 4.30 ratio ring and pinion
* New Detroit locker
* Professionally rebuilt by a long standing reputable differential shop (30 years)
The parts and labor to create this example was $1900; sell $799.
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More Diff0211
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More Diff0110
9-inch 3rd member, 3.70:1, “N” nodular iron case, billet 1350 yoke with integral drive pulley, clutches with purple spring, 31 spline, very low use and still has white grease from last inspection & setup. Originally cost $2100 when built and prepared, sell $799.
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 370_0111
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 370_0211
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 370_0312
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 370_0411
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 370_0512
9-inch 3rd member, 3.50:1, "9+" aftermarket nodular iron case, clutches with black spring, 31 spline, light use power-wise, needs final setup (torque ring gear bolts, etc), $599.
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 350_0110
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 350_0210
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 350_0310
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 350_0410
370 heads, cores, $100
Borg Warner T-19 4-speed trans, from 1985 F-250, xlnt cond. $350
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More T1910
429 Commercial center-dump manifolds, $50/pr
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More 370man11
460 D5TE truck manifolds, $50/pr
All prices are "plus shipping" unless otherwise noted, package deals will be considered.
Please call High Flow Dynamics directly if interested. 31Zero-435-19ZeroZero
View user profile http://www.highflowdynamics.com
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More Empty Re: SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More
Post  glenevans on November 7th 2017, 2:48 pm
I'll take the Scat 4.500 crank. Thanks
glenevans
Post  Boyd10 on November 7th 2017, 2:53 pm
Mr Paul could you text or call me? Maybe interested in a few things. 912-281-9321
Boyd10
Post  Boyd10 on November 7th 2017, 2:54 pm
912-281-9321
Boyd10
Post  Paul Kane on December 16th 2017, 3:10 pm
Post  wayney on December 17th 2017, 4:40 pm
pics of the crower rods? what bolts are in them?
wayney
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More Empty SCAT 6.7 Rods
Post  wickettoby1 on December 18th 2017, 10:11 am
What is the part # on the SCAT 6.7 rods?
Justin
wickettoby1
Post  dfree383 on December 20th 2017, 6:29 pm
Paul got any forged cranks?
Post  Paul Kane on December 20th 2017, 11:06 pm
wayney wrote:pics of the crower rods? what bolts are in them?
Pics added. The bolts are Crower bolts, of course.  Any other questions please give me a call, thanks.
wickettoby1 wrote:What is the part # on the SCAT 6.7 rods?
Justin
Should be shipping tomorrow, Justin, thanks.  P.S.: 8740s.
dfree383 wrote:Paul got any forged cranks?
Yep, still gotta sift though 'em.  Probably going to be the 4.25"-4.50" stroke arms, some billet, some forged, some Ford ends, some not, some mixed ends.
Post  wickettoby1 on December 21st 2017, 12:01 pm
Paul
I'd be interested in a forged 4.5 stroke crank if you happen upon one and dfree hasn't already called dibs.
Justin
wickettoby1
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More Empty SCAT Rods
Post  wickettoby1 on December 26th 2017, 5:05 pm
SCAT Rods arrived, thanks Paul.
Justin
wickettoby1
Post  slurm on January 2nd 2018, 7:41 pm
Everything looks great thanks again. Lonny
slurm
slurm
Post  Paul Kane on April 19th 2018, 7:51 pm
Post  octanehuffer on April 22nd 2018, 12:03 am
I'd like those Trick Flow valve covers. I'll call on Monday
octanehuffer
octanehuffer
Post  Paul Kane on July 23rd 2018, 4:21 pm
Post  Paul Kane on January 23rd 2019, 3:03 pm
Post  RAPIDGT on January 25th 2019, 4:38 am
pics and price on the commercial manifolds shipped to 38571?
RAPIDGT
Post  ChrisH on January 26th 2019, 8:55 pm
Paul
I’ll call monday but I am interested in the 4.5 lunati crank and the 6.8 oliver rods. Unless there is something really beat up on these ( which I doubt) I will take them both.
thanks
Chris
ChrisH
Post  Paul Kane on May 10th 2019, 1:47 pm
Updated
SPRING CLEAN 2019 UPDATE - GARAGE CLEANOUT - Differentials, Heads, Pistons, Crankshafts, More Bump
