Jon Kaase SR71 Cylinder Heads
+63
mitch huested
away
torino501
427John
CDMBill
Carbguy
SandHillsHillbilly
Lukesportsman
Ol'Blue77
Mikejc
6t6mustang
MidnightbluS10
psfracer
terryk105
BBF552
ED468
fordsrgrt
nitrous.f
Carl
boss9coupe
nuclearcobra
Stimie
Mark O'Neal
cobrakid8
Coupe Devil
STR-LGL-70
DGS
Gary Blair
glenevans
litshoot
jonkaase
68galaxie
JBR-3
nascar429
wayney
enginetech
67 posters
Page 1 of 12
Page 1 of 12 • 1, 2, 3 ... 10, 11, 12
I just watched a new episode of Geerz and his latest project is an old 1959 Ford panel truck. But the engine is a Jon Kaase built BB with his new SR71 cylinder heads I checked Jon's web site and saw no info on them. Maybe he'll see this and chime in.
SR-71 Cylinder Heads
Maybe (finally), a worthy competitor to the SR-20? Though we will play hell getting it approved for use in those limited classes requiring “conventional” heads, whatever the hell that means.
enginetech- Posts : 15
Re: Jon Kaase SR71 Cylinder Heads
Raised intake ports. Requires china wall spacers like the 7721 edelbrock sbf head.
Lem,
Just how much are the intake ports raised?
https://staceydavid.com/projects/sr-71/
Lem Evans wrote:Raised intake ports. Requires china wall spacers like the 7721 edelbrock sbf head.
Good eye Lem. They dropped in a lifter valley plate then the manifold. They said it made 1027hp @6700 and 903tq @ 4600 with the TBS 871 blower on pump gas. He also said it had longer valves with a diameter of 2.375 In. and 1.76 Ex.
Doug Rahn wrote:Lem Evans wrote:Raised intake ports. Requires china wall spacers like the 7721 edelbrock sbf head.
It wasn't my eyes. Jon told me about the heads about a year ago.
I have repeatedly said we needed a bbf head like this since the P51 came out . wonder if it uses a mafia intake or dedicated for this head?
wayne
wayney- Posts : 187
Why does their 1959 panel truck look like a 1960 model??
BBFTorino- Posts : 982
https://i0.wp.com/staceydavid.com/wp-content/uploads/2018/08/Jon-Kaase-and-Stacey-.jpg?ssl=1
jbozzelle- Posts : 3705
[quote="Lem Evans"]
What I remember from talking about it at the PRI show was it was going to have an extended intake flange face so a regular CJ manifold would still fit. I hope that is still the case.
Does look like the intake face is extended with the picture of Kaase and David. That's pretty slick.
TravisRice- BBF CONTRIBUTOR
TravisRice wrote:Does look like the intake face is extended with the picture of Kaase and David. That's pretty slick.
Extented, kind of like the Edelbrock 7721 15* sbf head that's been around for years.
Nice chambers. Are these heads set up to use the 18 bolt system??
Also, any preliminary flow test data on them??
For the expert builders.....where do these heads fall in the pecking order of the BBF cyl. head list??
rmcomprandy wrote:Lem Evans wrote:Doug Rahn wrote:Lem Evans wrote:Raised intake ports. Requires china wall spacers like the 7721 edelbrock sbf head.
You are correct Randy. I went back and watched the video again and the blower intake used was a TBS off the shelf CJ unit and off the self headers with CJ pattern.
BBFTorino wrote:Nice chambers. Are these heads set up to use the 18 bolt system??
x2
SR-71 cylinder heads
Not exactly competition for the SR20. What exactly is the gain (in hp) in raising the CJ intake port location for a typical N/A combination?
enginetech wrote:Maybe (finally), a worthy competitor to the SR-20? Though we will play hell getting it approved for use in those limited classes requiring “conventional” heads, whatever the hell that means.
How conventional can they be if the factory valve covers and intakes wont even fit????
http://brodix.com/heads-2/big-block-chevrolet-compatible-heads/sr-20-series-cylinder-heads20
Last edited by JBR-3 on October 17th 2020, 3:19 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Cool looking heads.
What is the application for these heads (if they actually start selling them)?
Looks like they use standard Victor or Mafia intake manifolds.
Standard CJ exhaust flange - raised? I can't tell.
The P51 and new AFR head make 900+ hp - I would guess this will support more?
Where does the A460 fit in this picture?
Always fun looking at new cylinder head offerings or potential ones.
68galaxie- Posts : 349
From Kaase
OK, here is a little info:
we have been working on this head for 4 years
we have been tight lipped about it because I want to have a good supply of complete heads in stock before we advertise it
we have 100 castings here now, about 50 are completely machined
we do all the machining in house
we have valves and guide plates for them in stock
the valves are 2.375 x 5.7, and 1.76 x 5.32
the exhaust side of the head is same as P-51, the valve cover rail on the exhaust side is stock height
the intake side of the head is 1/2" higher than stock, but you can see the pictures, it's not very noticeable
the intake valve bowl is about 1/2" deeper
the exhaust valve bowl is about .300" deeper
We have done lots of dyno testing on a 598, 4.6 bore x 4.5, flat top pistons, 15 to 1, cam is 286-296-114, .460 lobe, Comp 1.73 steel stud mounted rockers with no stud girdle, wet sump, at times vacuum pump
the heads are unported but the chambers come cnc finished
the manifold is an unported Trick Flow for 4500 with big Dominator carb
the power has been 1080-1130HP, with the 1130 using a vacuum pump and port matched intake
some of the runs were never under 1060HP between 6100 and 7800 rpm
they are planned around a 4.5 to 4.625 bore
they will work on a 4.390 bore
I can answer any questions on this thread.... Kaase
jonkaase- Posts : 81
nosstang85 likes this post
» ISO BBF Mad dog 4x4 header's part # 9229 & P51 or Sr71 cylinder heads
» The new SR71 heads
» Kaase SR-71 Cylinder Heads
» Jon Kaase SR71 Build and Dyno results that he also tested with a Tunnel Ram
» Sr71 heads!
» Sr71 heads!
Page 1 of 12
