C6 build
C6 build Empty C6 build
Post  Fast Bear 22nd December 2017, 19:37
Talking to lots of people about a build and getting confused . I have a 521 with approx 600hp in a 56 f100 column shift . What do you guys think I should have for the build .....
Fast Bear
C6 build Empty Re: C6 build
Post  Gregaust 23rd December 2017, 03:20
5 clutches in each pack, #9 roller thrust, good servo and a good valvebody kit , Transgo 67-2 kit would be good . Be selective which pan you use to give plenty of oil
There's plenty you can do Smile
Gregaust
Post  Fast Bear 23rd December 2017, 09:38
Thanks mate. . What's this talk they say about drilling the drum for oil to release out of the clutches ? Or I don't need to worry about this sort of thing for my application ? ......
Fast Bear
Post  Gregaust 24th December 2017, 03:15
Quite common to drill some holes around the high/reverse drum, does allow oil to release and flow through to keep clutches cooler also
Gregaust
Post  DeepRoots 27th December 2017, 13:37
Lemme try to load a picture of a drum with the holes drilled.  never did on this forum
Nope... this place sucks for that. sorry.... good luck
DeepRoots
Post  Gregaust 28th December 2017, 05:37
There's a few ways can be done . Can do 4 evenly spaced holes approx 1/4" each, or multiple 1/8" holes in a pattern as per Franks instructions .
Gregaust
Post  gt350hr 28th December 2017, 13:18
Use a  Kevlar "flex" band , standard width.  I'm just finishing my own and I went with the wide ratio gear set , CJ governor , Summit "no name" deep aluminum pan, and Superior ( no machining)servo. The rest is like Greg laid out 5 clutches and needle bearings wherever possible.
gt350hr
Post  Fast Bear 31st December 2017, 01:25
Cheers thanks guys . I'll find franks instructions . It would be good to see a photo.....
Fast Bear
Post  Gregaust 31st December 2017, 02:33
What photo's you need ? Just near impossible to post now without photbucket. Need to find a new host ..
Can email if that helps
Gregaust
Post  Fast Bear 31st December 2017, 08:25
Greg it would be great just to see how it's done And my interest is where in the pack is the holes in relation to the drum ... mandmdavis1@bigpond.com
Fast Bear
Post  aquartlow 31st December 2017, 10:18
Not sure if this would help, but found this on Ebay:
https://i.ebayimg.com/images/g/mqgAAOSweW5Vbcmo/s-l400.jpg
aquartlow
aquartlow
Post  Fast Bear 31st December 2017, 18:33
Wow . That's full on . I didn't think there is that many holes . Thanks for the link aquartlow.
Fast Bear
Post  Gregaust 1st January 2018, 03:41
That looks like one of Franks drums . You can do like that is one way . Or 4 evenly spaced holes also works ok if using basic shift kit type mods . Have sent email with some pics and info.
Gregaust
Post  DeepRoots 1st January 2018, 10:38
Since photobucket killed all of my old threads, I started a facebook business page for my projects.
This is one on doing a full roller c6:
https://www.facebook.com/pg/AirFuelSParkTech/photos/?tab=album&album_id=174252049980201
DeepRoots
Post  Gregaust 2nd January 2018, 04:46
Nice work, i'll give ya a like to follow Smile
Another good FB group for c4 + C6   https://www.facebook.com/groups/1691753204407031/
Or for C4 , be sure to answer the question if you want in Smile   https://www.facebook.com/groups/1777735895808107/
Gregaust
