Rod to Rod Clearance. What is too tight with a steel rod?
Post  747JetMech on February 1st 2018, 12:39 pm
Putting my Cleveland Stroker together and have only .011 to .012 clearance between rods. Is this too tight for a steel rod?
Thx..
747JetMech
747JetMech
Re: Rod to Rod Clearance. What is too tight with a steel rod?
Post  rmcomprandy on February 1st 2018, 8:07 pm
747JetMech wrote:Putting my Cleveland Stroker together and have only .011 to .012 clearance between rods. Is this too tight for a steel rod?
Thx..
4 times the bearing clearance is the "rule of thumb" minimum.
EDIT; just use a feeler gauge between the rods.
Last edited by rmcomprandy on February 6th 2018, 12:39 am; edited 2 times in total
Post  747JetMech on February 1st 2018, 8:15 pm
Thanks Randy.
747JetMech
747JetMech
Clearance
Post  747JetMech on February 5th 2018, 10:55 pm
Hi Randy
I am running a SCAT crank rod bearing clearance is .0025 with a chevy rod journal of 2.000.. I put a dial indicator at each journal and it reads between .011 and .010. Too tight? What is the proper way to the clearance?
Tom
747JetMech
747JetMech
