bbf bolt size
bbf bolt size
im sure its been asked or posted before, replacing the standard timing cover with danny bee belt drive, my problem is i no longer have the original bolts (moved and dont remember where they went or what box their in) that were holding the cover on, looking for the thread pitch for the bolts, and how long if you dont mind,
Rickytx630- Posts : 100
Re: bbf bolt size
Rickytx630 wrote:im sure its been asked or posted before, replacing the standard timing cover with danny bee belt drive, my problem is i no longer have the original bolts (moved and dont remember where they went or what box their in) that were holding the cover on, looking for the thread pitch for the bolts, and how long if you dont mind,
This might be a start for you. 5/16 - coarse. = 5/16-18
https://www.429-460.com/t13463-timing-cover-bolts
Here's another possibility- I can't verify accuracy of this product.
https://www.ebay.com/itm/FORD-429-460-big-block-water-pump-timing-cover-stainless-steel-hex-head-bolts/152939874921?hash=item239bed4a69:g:3fAAAOSwVC1Zz~eC
And this....... https://www.429-460.com/t19864-waterpump-timing-cover-bolts
Colt Macara- Posts : 132
» 4 bolt main conversion? Or 2 bolt main stud girdle?
» timing cover bolt kit ? or size needed
» Stock harmonic balancer bolt HEAD size?
» tire size to gear size
» Best 4-Bolt caps/DOVE-A 2 Bolt
