Cummins 3029514 Turbo
Post  STR-LGL-70 on April 21st 2018, 2:36 pm
I have a Cummins turbo with P/N 3029514 ID tag on it, would this work (be worth using) on say a 501" engine? Maybe someone on here knows if this is worth using? Too small/too large in a single turbo set up?
Thanks, Sheldon
STR-LGL-70
STR-LGL-70
Re: Cummins 3029514 Turbo
Post  STR-LGL-70 on April 27th 2018, 10:19 am
So I did some measuring and this is a 80MM turbo, is this too small for a single on a 501" to 533" engine?
Thanks, Sheldon
STR-LGL-70
STR-LGL-70
Post  tbirdmike on May 7th 2018, 1:57 pm
depends on your goals with it.
It kinda looks like it has a t4 turbine housing. Whats the turbine wheel out let size?
tbirdmike
