eccentric help
eccentric help Empty eccentric help
Post  PAPPY Wed 6 Feb 2019 - 17:16
Am in the process of a build and purchased a custom grind cam from Bullet Cams. It came threaded for a 7/16" bolt so I had my eccentric drilled out na got a larger bolt. All well and good until assembly .I noticed a small crack in the inner piece of the eccentric by the bolt hole. So I have been searching for a new one but can only find 1 with a 7/16 hole, its a frpp 1 piece. MY question is is that compatible or does anyone have other options. Thanks in advance..
PAPPY
eccentric help Empty Re: eccentric help
Post  away Wed 6 Feb 2019 - 18:16
If you are running the stock fuel pump this should work. If not throw it away assemble without it and block off the timing cover with a plate.
away
away
Post  rmcomprandy Wed 6 Feb 2019 - 18:58
PAPPY wrote:Am in the process of a build and purchased a custom grind cam from Bullet Cams. It came threaded for a 7/16" bolt so I had my eccentric drilled out na got a larger bolt. All well and good until assembly .I noticed a small crack in the inner piece of the eccentric by the bolt hole. So I have been searching for a new one but can only find 1 with a 7/16 hole, its a frpp 1 piece. MY question is is that compatible or does anyone have other options.  Thanks in advance..
A eccentric for an FE engine is usually a two piece but, it does have a 7/16" hole.
Post  PAPPY Thu 7 Feb 2019 - 11:51
Just wanted to thank every one. I ordered the fe type so that should fix me up.Also went one piece. Thanks again!!!!
PAPPY
Post  racinghabbit Thu 7 Feb 2019 - 12:29
comp timing sets #7122 tell you to use the one piece ... I just went threw it.
racinghabbit
racinghabbit
