Hello from Lloydminster Alberta
I am a ford guy from Lloydminster Alberta
I just finished building a 557 BBF.
Which will be going in my 90lxcoupe.
Also have a 2013 boss mustang with a few mods.
90lxcoupe- Posts : 12
Re: Hello from Lloydminster Alberta
Welcome,
Tell us more, and show us some pictures.
FalconEh- Posts : 1448
Hello
The 557 started as a 73 stock block that I had and did lots of machine work on it .
Converted it to a 4 bolt main on the 3 center caps
Deck and bore to 4.440 , filled 3/4 with block cement . .the rotating assembly is forged scat .
Je pistons arp main studs made up the short block
The top end consists of tfs a460 heads 340 cc
Tfs intake comp cams solid roller and comp cams lifters td shaft rockets 1.75 and a pro-systems 1150 domintor carb
Welcome aboard. We have several Albertans on here.
jasonf- BBF CONTRIBUTOR
Welcome!
68galaxie- Posts : 349
» new guy from Alberta
» hello from Alberta Canada
» Ken from Calgary Alberta
» Hi from Southern Alberta
» Alberta Boys
» Alberta Boys
