502 F350 engine
Page 2 of 4 Previous  1, 2, 3, 4  Next
502 F350 engine - Page 2 Empty Re: 502 F350 engine
Post  Nevs on January 2nd 2010, 5:38 pm
bruno wrote:sweet build Lem ..... it would also be cool to see what kind of mileage this piece would get once it gets on the road Question
I'd be curious on the mileage as well. Nice numbers regardless.
Post  Lem Evans on January 2nd 2010, 9:35 pm
I will report back . One thing I can tell you is that it feel damn good to not being looking for fuel every time we looked up...compared to the big HP units with 1250s attached Very Happy
Post  bbf-falcon on January 2nd 2010, 10:12 pm
Thats a good topic Lem Wink How much fuel will a 900/1000 hp engine use on each pull Question
Post  Lem Evans on January 2nd 2010, 10:14 pm
It's the warm-up....oil temp mostly that kills you Evil or Very Mad
502 F350 engine - Page 2 Empty very nice!
Post  blown473 on January 3rd 2010, 12:50 am
Impressive #s , and a very good looking motor as well. Like the cherry m/t valve covers, haven't seen a pair that clean in at least a decade. That would be an awesome spec motor for a classic old Ford p/u. Talk about driveability! Torque to break the back end loose at will!
blown473
blown473
Post  dfree383 on January 3rd 2010, 10:23 pm
bbf-falcon wrote:Thats a good topic Lem Wink How much fuel will a 900/1000 hp engine use on each pull Question
EMC motors in the 750 hp range with 2 dominators seemed to go thru about 10 gallons a day, probably 15-20 pulls or so.
Post  bruno on January 3rd 2010, 10:41 pm
i believe Lem and Bob went thru 5-6 gallons of fuel on a dozen pulls on the 562 .... i believe
http://WWW.CKRME.COM
Post  schmitty on January 3rd 2010, 11:52 pm
When my motor was on the dyno down at Bret's, the readout for fuel consumption at WOT was 75gal/hr Shocked . This was on a baby motor with only about 600hp.
Post  richter69 on January 4th 2010, 12:32 am
we only went through 7 gals of methanol when we did our smallblock, that was breakin, 2 warmups, and over a dozen pulls.
Post  83-88T-Bird Guy on January 4th 2010, 1:04 pm
Lem Evans wrote:TFS street/strip heads
J429 FRPP manifold [performer rpm]
218*/224* comp hyd. flat tappet cam
QFT 735 VS carb
9.25/1 comp ratio
Interesting....a 218-224 @.050 cam making that kind of power with 9.25 to 1 c.r.. What's really interesting to me is that the torque band from 2500 to 4600. It never dipped below 548 ft lbs !
Equally impressive is the 450 hp and 578 ft/lbs at 4100 rpm which I believe is the shift point for a C-6 trans. (under full throttle) Very Happy
Thanks for posting Lem !
83-88T-Bird Guy
83-88T-Bird Guy
Post  droppedf100 on January 6th 2010, 3:01 am
Do you think the motor would lose much with ported bigger valve D0VEs flowing 313/182 at .600 lift with everything else the same. Maybe a bigger cam but still hyd.
droppedf100
droppedf100
Post  the Coug on January 6th 2010, 7:41 am
Lem the funny thing is Blake and I were talking a month ago about building an engine identical to this but using Pro Crap heads to keep the compression down, we figure it should build around 400 to 425 hp and have about 550+ torque, but thats the only thing I can think those heads would ever be good for....but I was thinking more like a 780 vs holley
Post  dfree383 on January 6th 2010, 10:10 am
droppedf100 wrote:Do you think the motor would lose much with ported bigger valve D0VEs flowing 313/182 at .600 lift with everything else the same. Maybe a bigger cam but still hyd.
I think you'd probably loose at least 40-50hp all things equal
Post  jones on January 6th 2010, 11:13 am
Good build Lem, there I thought you never fooled with these small engines! Although this build doesn't help my confidance in my build that I will come close to my goals.
jones
Post  The Mad Porter on January 9th 2010, 1:20 am
Outstanding Lem...
Looks like you found a bit more after we talked.
Small cam plus good heads = big hp at reasonable RPM.
This is a lesson that many should heed. Its all about the combination of parts...
Damned near 1 HP per inch at 4700 RPM Damn!!! Shocked
Very Happy
The Mad Porter
The Mad Porter
Post  The Mad Porter on January 9th 2010, 1:29 am
Given the TFS streets flow of about 335 @ .600" lift and the better exhaust port you would be short 20 to 30 HP with your heads.
In this particular application I would bet a pair of my 332@ .600" intake and 200@ .600" Doves would generate very similar numbers vs out of the box streets. Ported streets are another story though how much flow does a 480 HP combo really need?
PS.
These numbers are SF110 and SF600 verified by Dave McLain and Bret powell...
Cool
The Mad Porter
The Mad Porter
Post  Lem Evans on January 9th 2010, 11:09 am
The Mad Porter wrote:Outstanding Lem...
Very Happy
Thanks Scotty . Finished it up New Years day . The last pulls were spacer tests....1" 4 hole hurt power and tq....1" open worse yet f.y.i.
The cam was but .515" lift , that's why I think a SCJA package would be good for a car engine .
Post  Tommyj466 on January 9th 2010, 12:08 pm
That is a real Torque-Daddy! Very Cool
TJ
Tommyj466
Tommyj466
Post  TravisRice on January 22nd 2010, 6:03 pm
I too was talking to Scotty yesterday about a similar build but 545 cubic inches and large valve D3's or Edelbrocks. He speced a cam very similar.
Wink
Travis
Post  Lem Evans on January 29th 2010, 7:26 pm
Bump for Paul.
Post  nickbay on January 30th 2010, 11:48 am
I would like to see what that engine combo would do in a small lightweight mustang. Cool
The low end torque would be quite a challenge at the track.
With a C6, just leave it in gear and let it shift by itself.
Heck you could run fairly high rear gears, run respectable ET's and still be able to cruise. cheers
nickbay
nickbay
502 F350 engine - Page 2 Empty 502 f350
Post  hdandford on January 30th 2010, 2:51 pm
that would make a good mud bog engine in a lower running class
hdandford
Post  cletus66 on February 1st 2010, 1:03 pm
nickbay wrote:I would like to see what that engine combo would do in a small lightweight mustang. Cool
I agree. I wonder how that would work in my '67 with a C6 and a 2.75:1 rear. 160 mph @ 5500 rpm. Shocked I would get arrested on the highway.. Embarassed
Post  billandlori on February 1st 2010, 1:42 pm
[quote="cletus66"]
nickbay wrote:I wonder how that would work in my '67 with a C6 and a 2.75:1 rear. 160 mph @ 5500 rpm. Shocked I would get arrested on the highway.. Embarassed
They got to catch you first!!! Twisted Evil
That kind of torque will pull a trailer inside-out. Great build!!
Bill
Post  dfree383 on February 1st 2010, 2:32 pm
[quote="billandlori"]
Bill
You can't out run Motorola....
