7.50 CERT UPGRADE ?
7.50 CERT UPGRADE ?
Post  bruno on January 7th 2010, 12:21 pm
So i was doing some pricing and to add the kidney bar and the foot bar and the 2 parellel bars to tie the foot bar in these guys want between 2500 - 3000 ..... theres maybe 100 in material needed ...why so much ?? does that sound right
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Re: 7.50 CERT UPGRADE ?
Post  Nevs on January 7th 2010, 12:22 pm
Sounds high to me. I'd shop around some more.
Post  D. Sea on January 7th 2010, 12:23 pm
bruno wrote:So i was doing some pricing and to add the kidney bar and the foot bar and the 2 parellel bars to tie the foot bar in these guys want between 2500 - 3000 ..... theres maybe 100 in material needed ...why so much ?? does that sound right
Nick,
OUCH! You need to bring your car to KY and have Bill update it for you. Look what' he's done with Chuck's new chassis Cool and he will save you a ton of $$$
Would be best to remove all the stuff first to save even more money but you would need to speak with Bill about that.
D. Sea
Post  bbf-falcon on January 7th 2010, 12:44 pm
I was talking to a friend of mine and yours couple days ago,and a really good chassis builder priced him a new chassis welded using all of his existing components for $3500
Post  LUNCHBOX on January 7th 2010, 2:43 pm
Is that enough to get 7.50 cert. I'm getting ready to do a whole new cage for 8.50 cert. I thought you need a x-brace in the floor. It's not cheap to have somebody else do the work. We had our dragster up-graded an it wasn't cheap nice work though.
LUNCHBOX
Post  jbozzelle on January 10th 2010, 12:17 pm
I'd shop the price...
I'd talk to some guys on here as well. Bill is doing good work on Chuck's car. What about that guy that is finishing up David Willingham's truck? He's in AL as well. I'm sure there are more. Just can't think of them. I'm still on my first cup of coffee... Sleep
Post  bruno on January 10th 2010, 1:01 pm
guys to complete my 7.50 cert i need bars 6a, 6b, 6c ,15 in cars of unibody construction do not need 8a or 8b and do not need 4 ( center x brace) from what i read and what i was told from nhra officials
JET BOAT BOB
Post  LUNCHBOX on January 10th 2010, 2:02 pm
Did you get a pic of what its supposed to look like. Are you using m/s or chrome moly. Why not fit it yourself and get someone to finish weld it .
LUNCHBOX
Post  whatbumper on January 11th 2010, 4:17 pm
We did the 8.50 to 25.5 cert for less than $1000 including the welding but we already had a good chromoly 12 pt cage. We used a wolfe funny car kit and they supplied the remaining needed bars. No x under floor because of the stock floor. I agree with LUNCHBOX, buy the SFI book and do it yourself if you can TIG weld or just hire out the welding after you fit everything. Not that big of a job IMO.
Post  deliveredfast on January 13th 2010, 9:10 pm
I talked to guy here in MI and he quoted me 3800.00 for a 7.50 cert crome moly starting from scratch.
deliveredfast
Post  Larry Williams on January 13th 2010, 9:17 pm
Tean Z in Mi has good prices on cages
Look at their web site
Larry Williams
Post  DILLIGASDAVE on January 15th 2010, 7:30 pm
It's true that the center floor "X" (#4) & outboard floor diagonals (#8 A&B) might not be needed for a 25.5 cert on a car that still has the factory OEM rocker panels, door hinge pillars, firewall, & floors (welded to the inner frame rails/sub frame connectors). But adding these bars anyway is still a good idea for a few reasons. Even though they might not be "required" in this situation, they will add strength to the structure & make it more rigid. And if the bars are already there you wont have to add them later if you decide to upgrade. Just because the structure is SFI "safe" doesn't mean it's also as strong/rigid as it can be.
In my opinion if nothing else the center "X" really needs to be there in any situation regardless of the minimum rules just because it will keep the rear crossmember (#1) & inner frame rails (#2A) square to each other. Best way to keep a structure straight & square is to add a diagonal and/or an "X".
Post  Outlaw5.0 on January 18th 2010, 8:15 pm
Larry Williams wrote:Team Z in Mi has good prices on cages
Plus their work is top notch.
Outlaw5.0
Post  bruno on January 26th 2010, 4:12 pm
DILLIGASDAVE wrote:It's true that the center floor "X" (#4) & outboard floor diagonals (#8 A&B) might not be needed for a 25.5 cert on a car that still has the factory OEM rocker panels, door hinge pillars, firewall, & floors (welded to the inner frame rails/sub frame connectors). But adding these bars anyway is still a good idea for a few reasons. Even though they might not be "required" in this situation, they will add strength to the structure & make it more rigid. And if the bars are already there you wont have to add them later if you decide to upgrade. Just because the structure is SFI "safe" doesn't mean it's also as strong/rigid as it can be.
thxs for the input dave
JET BOAT BOB
Post  Barney on January 29th 2010, 7:01 pm
It was a shade over 3k for my 25.5 upgrade.
Barney
View user profile http://www.hdraracingseries.com
