Distributor hole plug
Page 1 of 1 • Share •
Who makes one for a BBF?
Thanks in advance.
Thanks in advance.
138n- Posts: 5
Re: Distributor hole plug
Not too dificult to make from an old core distributor. Use a hacksaw.
chuck stevens- Posts: 299
chuck stevens wrote:Not too dificult to make from an old core distributor. Use a hacksaw.
im guessing you remove the gear and just let her set in the hole .....
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
bruno- Moderator
If you need the oil pump drive, do what Chuck said. If you don't need the drive, someone like David Willingham could make you a nice aluminum plug with an "O" ring groove at a reasonable price. Or if you want to go cheap, you could go to NAPA and find the appropriate size core plug, and tap one in.
Doug Rahn- Posts: 829
138n wrote:Who makes one for a BBF?
Thanks in advance.
could the factory 5.0 distribtorless one be adapted with the correct gear and shaft mods??? I've never see it attempeted but it might be worth looking at???
dfree383- Posts: 5980
take a frezzplug, drill a hole in it,use a old crome lug nut,and a 1/2 bolt from bottom, and set it in there,done. great for storing engines
BOSS 429- Posts: 1307
If its for storing it then the tapered rubber plugs from the hardware store work great,i also use them for the inlet/outlets on the radiator if i have to take it out.
nuclearcobra- Posts: 919
