Bench Racing: Highest horsepower N/A 10.3" deck engine combo's
Page 1 of 6 1, 2, 3, 4, 5, 6  Next
Post  fox331 on January 30th 2010, 8:59 am
Just studying some cylinder head potential, and got to dreaming. I was wondering what is the highest horsepower anyone has gotten out of a 10.3" deck motor?
What about the highest horsepower with a Hemi layout?
Details please, if you are willing to share.
fox331
Re: Bench Racing: Highest horsepower N/A 10.3" deck engine combo's
Post  dfree383 on January 30th 2010, 9:50 am
I'd think in a max effort hemi 1600ish wouldn't be out of line n/a. Of course that involves alot of rpm and $$$$. Something in the 690" range.
Post  FORDMUD on February 1st 2010, 2:46 pm
Is it possible to get 690 out of a 10.3 block?
FORDMUD
Post  schmitty on February 1st 2010, 3:20 pm
4.7" bore and 5" arm will get you there, and it can be fit into a 10.3 Eliminator block I believe. Cool
I know the Thor's will go over 1300 hp properly set up, and that is the top of the line in wedge heads for the BBF. Cool
Post  FORDMUD on February 1st 2010, 3:25 pm
That sounds pretty sweet.
FORDMUD
Post  dfree383 on February 1st 2010, 4:14 pm
FORDMUD wrote:That sounds pretty sweet.
Yes it does....... Exclamation Exclamation study
Bench racing
Post  fox331 on February 1st 2010, 9:06 pm
What about the A460's for a slightly more conventional head? What is the highest horsepower anyone has seen out of these heads, especially with their cast tunnel rams?
fox331
Post  schmitty on February 1st 2010, 9:16 pm
I think the king of the hill on the A's goes to Phillip Oakley's 604 @ 1100+hp, unless you get ole Hemi's buddy to build you one that did 1300.
Post  Nevs on February 1st 2010, 9:26 pm
schmitty wrote:I think the king of the hill on the A's goes to Phillip Oakley's 640 @ 1100+hp, unless you get ole Hemi's buddy to build you one that did 1300.
Our A head 557" dyno'd 1110hp. So, obviously 1100 is doable...
Post  schmitty on February 1st 2010, 9:36 pm
Nevs wrote:
schmitty wrote:I think the king of the hill on the A's goes to Phillip Oakley's 604 @ 1100+hp, unless you get ole Hemi's buddy to build you one that did 1300.
OOPS not a 640, more like 604 ci. Embarassed
Post  fox331 on February 1st 2010, 10:26 pm
A 557 at over 1100hp? Very Impressive!
Details please.
fox331
Post  adrenaline269 on February 1st 2010, 10:43 pm
what about a c-460 headed motor? My c heads peaked at 515cfm and are going on a 598 a460 block about 13.5:1 comp, Nitrous deal, sheet intake and twin 2000cfm throttle bodies.
adrenaline269
Post  Tony M on February 2nd 2010, 12:24 am
I had the same combo, c-heads 13:5 compression, sheetmetal and 2 BRE 1200 cfm carbs and made an honest 1200. Are you using a N20 cam with your injection ?
Tony M
Post  Tony M on February 2nd 2010, 12:34 am
fox331 wrote:A 557 at over 1100hp? Very Impressive!
Details please.
With out a power adder ? Nevermind the details. Is he taking new customers? Please give me his name and number. My cousin has a 604 a-head collecting dust that needs to be completed. Shocked
Tony M
Post  adrenaline269 on February 2nd 2010, 1:23 am
Yes I am building a n2o deal. Will be using a cam for n2o, with the efi set up. TS were you spraying yours? If so about how much n2o?
adrenaline269
