Which fuels do you all use ?
Page 1 of 1 • Share •
Has anyone had any experience with using "Propane" for their fuel ? I drove propane trucks and I do know that the propane is about 107 to 112 octane . I know their is a conversion for the GM's that I drove but anyone know if one is for Ford . With that much octane should perform very well PLUS it is COLD ! Show produce some high HP engines cheaper than fuel . No carbon at all and got over twice the life out of a stock Chev 350 . Just change the carb and did the propane set up . It's a very cold liquid that changes to a very cold gas .
Just a thought !
Jim
Just a thought !
Jim
RetroJim- Posts: 57
Re: Which fuels do you all use ?
I like the "nitropropane" in my alky...................
make car go very fast.
I think some of the Aussie guys on the other site use it.
richter69- Posts: 7431
I use Q16. Works very well. Runs cool, makes a $hit load of power, but cost a bunch. We also have to pretty much treat our motor likes it's an alky motor. Don't have to change the oil as much.
whatbumper- Posts: 1714
I Use C25 fuel,It's very expensive,But if you base it on cost per pass it's actualy pretty reasonable,the C25 i buy is in 5gallon(17.50 Gallon) cans.I can drive to the stagging lanes,do a burnout,stage car,make 8th mile pass,go across weight scales,and return to pits and only use a little over 1gt.That brakes down to about $4.50 a pass.This is all based on a 900hp 440In Yates C3 headed Windsor in a 2870 lb 10.5 tire car.Also shifts at 9100rpms. How i dont think there is any other fuels that are that efficient out there.When i used alcohol on a simular engine i would use about 1 and1/2 gallons per pass,Depending on were you bought the alcohol that still at the best cost over $3.00 per pass.Every engine is different but for my combo C25 works great.And is a lot safer.because i how run a 1 gallon fuel cell and if the ever is a problem i would rather have less than a gallon of fuel fire to deal with than 5 gallons of alcohol,thats hard to see burning.Hope that helps.
Last edited by Spencer Elton on Sun 21 Feb 2010 - 15:50; edited 1 time in total (Reason for editing : Corrected Fuel Cost)
Spencer Elton- Posts: 27
I rund Sunoco Max nos on my 383 windsor spraying with 175-325n20 worked great good fuel no problems and no detonation also left a good fuel ring easy to read on the plug almost a yellow tint
studly- Posts: 454
At the recent BBF Winter Tech Seminar, Don and Donnie Bowles were talking about Susan (Daughter of Jack Roush) running Propane in her car next year.
D. Sea- Posts: 2122
I ran 93 octane in my cleveland with a snow boost controller system.
had over 12:1 compression no ping at all.
debating on running it with my 557 if and when i can ever afford a set of heads
Maddmattmustangs- Posts: 1193
What is wrong with your heads you just ported, they sounded pretty darn good.
342g- BBF CONTRIBUTOR
richter69 wrote:I like the "nitropropane" in my alky...................make car go very fast.
Few years back my chassis guy got a race cart in trade for some parts... And had some nitropropane from who knows where...
I had never heard of it before then, but next thing I knew we were all ripping the cart around pushing a pretty cool flame outta that Briggs' pipe!
Hahaha... the memories... that stuff really did give the cart a kick in the ass - we gained a few MPH outside the shop
DFI429- Posts: 272
342g wrote:What is wrong with your heads you just ported, they sounded pretty darn good.
weight sadly. that and so far ive got the intakes barely pushing 330 cfm
