mid plate problem plz help!!
Page 2 of 3 • Share •
Page 2 of 3 •
1, 2, 3
Re: mid plate problem plz help!!
i get the feeling Dan did the trimming.
342g- BBF CONTRIBUTOR
Here is the one I modified for the smallblock, note the holes through the firewall behind the tab on the top, I had some steel dowls made that will go through the holes and weld into the cage structure. Just use some bolts to go through and tie it into the midplate.
richter69- Posts: 7462
Nice pic Jon.
Are you going to add some sliders for the plate to slide into position on?
jbozzelle- Posts: 2009
Anybody got any pics of how you mounted the Lat limiter bars ? This is my first car I'm learning And what about mounting a c6 what mounts are yall using. Thanks for the help I wouldn't b able to build a car without it !
Big block fox 339- Posts: 260
jbozzelle wrote:Nice pic Jon.
I always leave the midplate in the car.
OK, how are you going to tie in that plate to the dash bar? Similar to your car? I plan to do the same to mine, but my dash bar runs striaght across from a-pillar to a-pillar right behind the instrument cluster...
similar to this...........I ran a bar across to the bars that go forward through the firewall.
What size rebar did you use on that gas pedal, Jon?
Greg_P- Posts: 1007
Greg_P wrote:What size rebar did you use on that gas pedal, Jon?
I used tubing, hollow in the middle.....lighter by a whole bunch.........
Gotcha. This whole time I thought that cross bar was the dash bar. My dash bar doesn't go that far forward. Not sure if the factory brake pedal assembly will allow a bar like that either.
There's room, a plasma cutter and tubing notcher are your friends.............
Alrighty I stuck the motor in what do yall measure to and from to square the motor in the car?
I'll get after it once the Superbowl is over... Thanks for the pics agin, Jon.
whats a superbowl?
richter69 wrote:whats a superbowl?
hmm maybe it's like a high performance toilet like a pro comp toilet or something
Page 2 of 3 •
1, 2, 3
Page 2 of 3
