mid plate problem plz help!!
Page 3 of 3 Previous  1, 2, 3
Re: mid plate problem plz help!!
Post  nitro717 on February 5th 2010, 7:53 pm
drop a plumb line off the front of your crank, trans tail shaft, then center of the pinion
nitro717
Post  Big block fox 339 on February 5th 2010, 11:27 pm
cool thanks for the pics
Big block fox 339
Post  D. Sea on February 6th 2010, 4:17 pm
More pictures here
http://s45.photobucket.com/albums/f75/Phantasea466/Big%20Block%20Fox%20Engine%20Plates/
D. Sea
Post  Big block fox 339 on February 7th 2010, 11:56 pm
Thanks for all the help I got the motor in today only one problem when I got the motor where I wanted it one header tube is touching the k-member not hard against it just touching will it hurt anything ?
Big block fox 339
Post  D. Sea on February 8th 2010, 12:58 pm
Big block fox 339 wrote:Thanks for all the help I got the motor in today only one problem when I got the motor where I wanted it one header tube is touching the k-member not hard against it just touching will it hurt anything ?
"tweak" it a little and make it fit Idea
D. Sea
Post  IDT-572 on February 8th 2010, 9:20 pm
(BFH) Cool
Post  Big block fox 339 on February 8th 2010, 9:47 pm
Alright got the header problem fixed tonight. Sorry I got one more question I'm a newb do I use the flexplate shield and the mid plate or just the mid plate?
Big block fox 339
Post  richter69 on February 8th 2010, 9:53 pm
I'd use just the midplate, its going to be thicker than the factory blockplate anyway. Make sure the converter spacing is ok.
Post  Big block fox 339 on February 8th 2010, 10:02 pm
Yeah the converter looks good this is my first time at this and I'm doing it alone so I was worried I needed to use both Thanks I coulnt do it without this site
Big block fox 339
Post  jones on February 8th 2010, 11:07 pm
Glad you was able to get a new plate made, I knew it wouldn't be a big step for a high stepper!
Note to everyone else: I am a fault for his first midplate. I had trimed it to fit my turbo Mustang build, as my headers where facing foward so I never looked at mid plate clearance for regular headers.
jones
Post  jbozzelle on February 8th 2010, 11:14 pm
richter69 wrote:whats a superbowl?
That super fancy football game the New Orleans Saints won...
Post  Big block fox 339 on February 8th 2010, 11:29 pm
jones wrote:Glad you was able to get a new plate made, I knew it wouldn't be a big step for a high stepper!
ha the plate was no problem after i figured out i could just make it how i wanted it lol
Big block fox 339
Post  jbozzelle on March 5th 2010, 11:13 pm
I tried to keep mine to where both ears would bolt at the frame rail area/height. The driver's side is like this, but the pass side is like yours. I'll end up with the midplate bolting to the frame brackets about 3-4" higher than the framerail.
