Valve Spring Retainer Question.
Page 1 of 1 • Share •
On a 466 ci. BBF turning 6,500 to 6,800 rpm are Titanium retainers worth the extra money or are the Chrome Moly ones okay to use?Aluminum A-429 CJ heads 2.20 intake valve 1.76 exhaust valve .670-.690 lift 256-266 duration at .050 camshaft.
Thanks Mark.
Thanks Mark.
Mark Miller- Posts: 605
Re: Valve Spring Retainer Question.
Mark,
If it is a racing engine, with a roller cam and some stout valve springs, I would go with titanium. If it is a street-strip engine and a flat tappet cam, and milder valve springs, then go with the steel retainers.
The purpose of titanium retainers and even titanium valves, is to reduce the mass, that the valve springs have to control. This let's the engine rev higher and it also extends the life of the valve springs.
On high rpm race engines, valve springs are a frequent maintence item. Depending on a number of factors, they may be changed out a couple of times in a season, or even more. Many of our guys, (Phillip, Kristina, Bobby, George and etc.) have spare valve spring sets in the trailer.
Hope this helps,
Uncle Charlie
Hope this helps,
Uncle Charlie
c.evans- Posts: 1398
uncle Charlie
Which is the bestest tool to use to change the valve springs? both on and off the engines
Larry Williams- Posts: 411
Larry,
For stud mounted rocker arms, the best low cost tool was the Manley cam-over tool, but they discontinued it. So now I have to buy the Moroso cam-over, and immediately modify it by welding on two triangular braces going from the main threaded part out over the top of the two paws. Basically the Moroso tool is too cheap/weak, but I can not get the old Manley anymore.
Of course for on the engine valve spring changing, you will be pumping air into the cylinder through the spark plug holes in order to hold the valves up. Wack the edge of the retainer with a dead blow hammer, in order to break the locks loose, before you use the compressor.
For shaft mounted rocker arms, I use a tool from T&D, and then make the axle to my specs.
For the real pro racers, you might want to check out the Buxton Engineering tools. I've used them on some high end, big valve spring pressure applications.
www.buxtonengineering.com
Hope this helps,
Charlie
Charlie
Hope this helps,
Charlie
Charlie
Charlie,
I have only had it to the track 2 times since 2004 so it sees more street driving than the strip.I'm using a spring with 225 lbs. closed pressure and 555 to 600 lbs. open pressure.Like i mentioned it's a solid roller cam .670-.690 lift and 256-266 duration at .050.Also i'm running the stock 2.20 intake and 1.76 exhaust valves that came from Ford Racing in my Aluminum A-429 Cj heads.Are they a decent enough valve to hold up to the 555 to 600 lb. open pressures for a reasonable amount of time?I'm on my 2nd set of valve springs now and have the Herbert Titanium retainers now but my buddy had a failure with one that's why i'm asking all the questions.
Thanks Mark.
Thanks Mark.
Ooops sorry i guess i didn't mention it was a solid roller cam in my original post.
Thanks Mark.
Thanks Mark.
Mark,
Those FRPP A-429 valves are fine. They are a very good quality valve and have certainly withstood more abuse than what you're doing with them. The Herbert titanium retainers should be just fine also. I suspect there may have been another problem with your buddie's engine, that was the real cause of the retainer failure. In your case, it seems that you do more street miles than any racing, so IMO if you want to go to a steel retainer, that's okay also. In your position, you could go either way, sorta' like stradling a fence.
Charlie
Charlie
You can also get lighter weight steel stuff.
dfree383- Posts: 5972
Charlie,
Thanks in a perfect world i would like to race my car 1 to 2 times a year but that never happens.Also dfree383 mentioned the lighter steel retainers who makes them?
Thanks Mark.
Thanks Mark.
Mark, ask dfree, but I assume he is talking about some of the Beehive retainers that go with the Beehive springs from Comp Cams.
Charlie
Charlie
It is Comp Cams thats now offering lighter weight steel stuff (not sure if their are others). I haven't had any in my hands but saw them in some advertising somewhere. They where being billed as "almost as light as TI" but alot cheaper, Probably has a good nitch with alot of guys builds.
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=1731-16&Category_Code=
dfree383,
Would those work okay with a 1.55" spring?
Thanks Mark.
Thanks Mark.
Mark Miller wrote:dfree383,
Thanks Mark.
what 1.55 springs? Check the comp catalog it gives the dimensions and other part numbers are avaliable.
The Beehive retainers I am using have the super locks and they seem to be real lite. Not the cheapest but cost less than Ti.
jones- Posts: 1399
dfree383,
Thanks i'll check them out when i get my tax money back,Later Mark.
