Rody Crankshaft? (the original post was a year ago)
Page 3 of 3 • Share •
Page 3 of 3 •
1, 2, 3
Re: Rody Crankshaft? (the original post was a year ago)
Seeing the kind of hp and rpm that the Scat forged stuff is being used in from guys here, I'd put their cranks up against the other brands any day.
Big Daddy has spoken
Proud founder of the Truck Mafia
Definately in favor of God and guns
schmitty- Moderator
460 crank
Too bad you didn't live closer I would just give you a stock 460 crank, I got quite a few laying around. Maybe you should head to an wreckers and buy a core with all the accessory brackets and such then you will have some spare parts.
JMO Mark
JMO Mark
Last edited by Mark Laczo on February 24th 2011, 1:12 pm; edited 1 time in total (Reason for editing : spelling)
Mark Laczo- Posts: 180
bigblockfox468 wrote:I thought I seen somewhere that said you are here in Michigan , whether that is the case or not talk with Adney![]()
Adney Brown –Performance Crankshaftinc
His signature describes his services pretty well, I think:
PERFORMANCE CRANKSHAFT INC,. YOUR FIRST STOP FOR CRANKSHAFT REPAIR , MODIFICATIONS AND CUSTOM CRANKSHAFTS /; ROTATING ASSEMBLIES ... coffee donuts and entertainment available at no extra charge ... shop phone 586-549-7557 lounge phone 313-873-6588
Hey bigblockfox468 i'm in leonard mi
dragweek quickest street rod
2009 2010
quick 52- Posts: 254
Mark Laczo wrote:Too bad you didn't live closer I would just give you a stock 460 crank, I got quite a few laying around. Maybe you should head to an wreckers and buy a core with all the accessory brackets and such then you will have some spare parts.
JMO Mark
This is an OLD thread from when I first joined here man
bb429power- Posts: 2741
quick 52 wrote:bigblockfox468 wrote:I thought I seen somewhere that said you are here in Michigan , whether that is the case or not talk with Adney![]()
2009 2010
Really........damn thats just a few miles from me. I'll PM you. be on the look out
bb429power wrote:Well its a 429 that I am putting a 460 crank in because of A I can't find pistons with a low enough compression ratio that I like for a 429, and B for more low end torque. Yes its going to be 550hp and 650ft-lbs, but its going to be street driven. Plus I don't like the idea of buying ANY used crank, I don't know how hard it was beat on.
Somebody mentioned you should listen to the builders on here, they won't steer you wrong.
342g- BBF CONTRIBUTOR
342g wrote:bb429power wrote:Well its a 429 that I am putting a 460 crank in because of A I can't find pistons with a low enough compression ratio that I like for a 429, and B for more low end torque. Yes its going to be 550hp and 650ft-lbs, but its going to be street driven. Plus I don't like the idea of buying ANY used crank, I don't know how hard it was beat on.
That was a while back, I have a much better head on my shoulders now
bb429power wrote:342g wrote:bb429power wrote:Well its a 429 that I am putting a 460 crank in because of A I can't find pistons with a low enough compression ratio that I like for a 429, and B for more low end torque. Yes its going to be 550hp and 650ft-lbs, but its going to be street driven. Plus I don't like the idea of buying ANY used crank, I don't know how hard it was beat on.
That was a while back, I have a much better head on my shoulders nowI have reread this thread a couple times and I'm like, what the heck was going through my mind?
Yea,that was two days ago, oong time.
342g wrote:bb429power wrote:342g wrote:bb429power wrote:Well its a 429 that I am putting a 460 crank in because of A I can't find pistons with a low enough compression ratio that I like for a 429, and B for more low end torque. Yes its going to be 550hp and 650ft-lbs, but its going to be street driven. Plus I don't like the idea of buying ANY used crank, I don't know how hard it was beat on.
ACTUALLY, look at the year of that post
There, I fixed the title to allude any confusion.
bb429power wrote:There, I fixed the title to allude any confusion.![]()
Thank you because I couldn't find a year of the post, of course I do have a jap made puter.
Page 3 of 3 •
1, 2, 3
Page 3 of 3
