E4OD w/ a 545 anyone?
Page 3 of 3 Previous  1, 2, 3
Re: E4OD w/ a 545 anyone?
Post  Greg_P on March 11th 2010, 8:37 am
I don't know what the limit is, but I do know that I pull lots of weight around with my E4OD/powerstroke combo in OD and it hasn't given any problems yet.
Truthfully, the E4OD stuff makes the AOD parts look like lego toys.
Greg
Greg_P
Post  Maddmattmustangs on March 11th 2010, 10:10 am
Greg_P wrote:I don't know what the limit is, but I do know that I pull lots of weight around with my E4OD/powerstroke combo in OD and it hasn't given any problems yet.
Greg
gah! now i dont know if i want an AOD or E4OD!.......
Maddmattmustangs
Post  windsor on March 11th 2010, 11:19 am
I'm sure the E4OD is very stout and stronger than the AOD considering the intended usage of each.
Considerations for which one to use should be size of the car, size of the tranny, if you want to use an electronic controller or not, ability to use lock-up converter, and bellhousing options.
A big car, like your Mustang or Greg's Torino, an E4OD is a fine option with some cutting like Greg did. I have a small 65 Falcon, so the AOD with adaptor bellhousing will work much better, but still required some cutting. Also, they are being built very strong these days!
Can't wait to hear about more results from your swap, Greg, especially what kind of times it will run now.
cheers
Post  Maddmattmustangs on March 11th 2010, 11:38 am
windsor wrote:I'm sure the E4OD is very stout and stronger than the AOD considering the intended usage of each.
cheers
X2
Greg do you have any mesurments on the trans such as the hight an width? I was looking at my drive tunnel and realized the previous owner had widened it a bit as well as made it taller.
Maddmattmustangs
Post  Greg_P on March 11th 2010, 11:52 am
I agree, Windsor, that the AOD is a good trans in the right applications. A light car with a small tunnel seems like a prefect application for an AOD in fact. The E4OD would certainly be overkill in a situation like yours.....
My car is so damn heavy, and we spray the snot out of it at the track, so I just didn't see an AOD surviving long for me.
I did not take physical measurements of the trans, but I do remember that it was around 6-8" longer than a C6. That wasn't the worst part, though. The C6 tailhousing tapers down real nice at the back. The E4OD stays really big back there and has a stubby tailhousing. Therefore, the real issue was making the rear of the trans fit the car.
The good news is a C4 trans mount works just fine on the E4OD.....lol......
Here's a link to the TorinoCobra site where I chronicled the swap from start to finish...... it might shed some light on the situation for anyone who might be interested in the conversion:
http://www.torinocobra.com/forum/viewtopic.php?t=13323
Greg
Greg_P
Post  Maddmattmustangs on March 12th 2010, 10:28 am
Good read cheers
like what you did with the C4 mounts lol!
Maddmattmustangs
Post  droppedf100 on March 14th 2010, 12:51 am
Id like to do the swap in my dads 95 Flareside with a carbed 460/c6. It only has 3.55s with 315/60s and its still 3000 at 70. Steady 902mph cruising would make long trips much more fun Smile
BTW my buddy has a 95 Lightning with a turbo windsor controlled by FAST and an E4OD with a Baumanator and he has it set to shift where he wants at wot.
droppedf100
Post  devildog on March 31st 2010, 2:19 pm
That is some cool shit...........good job Greg.....trying to catch up on here!.....D
devildog
Post  Greg_P on March 31st 2010, 8:15 pm
Thanks brother! So far so good, the car has made a decent pass and gone almost 200 stret miles without a failure yet.......lol.......
Greg
Greg_P
Post  TorinoGT on April 2nd 2010, 5:18 pm
Hows the car shifting? under typical street driving? under stoplight racing driving? etc etc? does the shift module compensate for throttle position/load etc... or are the shift points always the same??
Shane
TorinoGT
Post  patfromjersey on April 10th 2010, 2:47 pm
Nice job Greg. Cool I just read through your posts on the torino site. Congratulations! cheers
patfromjersey
