crank pilot delemma
Re: crank pilot delemma
Post  TorinoGT on March 6th 2010, 12:28 pm
...you live in Plymouth MI... and you cant find a used 460 crank? this is the motor city... there are TONS of junk yards in Detroit, some are "you pick", others you can buy the specific parts from the counter... every time I go to the you picks (like parts galore on 8 mile n hoover or livernois & warren) I see several late 70s fords/merc/lincolns with 460s in them, that would make great cores to do a rebuild off...
I also see 460s for sale all over craigs list.
Shane
TorinoGT
Post  BB94STANG on March 6th 2010, 11:03 pm
the Coug wrote:I think the silly thing is you buying a stock stroke aftermarket crank, when the factory is a much stronger and better piece all together.... but to each his own....
Yep....we alll know that ALL Eagle stuff is crap. Thanks for helping the guy out. Rolling Eyes
BB94STANG
Post  bb429power on March 21st 2010, 2:15 pm
I finally found a stock 460 crank, does anyone know what the crank pilot would be on it?
bb429power
View user profile http://michiganmotorheads.forumjonction.com/
crank pilot size.
Post  fordman460 on March 21st 2010, 3:11 pm
fordman460 wrote:Nope. But check your crank for both. It could have both 1.85 and 1.35 or 1.25. 1.25 is not a factory converter size.
Gotta measure it, Dude. You got calipers or a snap gauge?
fordman460
Post  bb429power on March 21st 2010, 3:37 pm
No, but I have the biggest micrometer they make. It goes to 3 inches, its the biggest I've seen. But I can take it to my machinists shop as he has the tools, I'm actually getting the crank through his friend. How could it be both? Inside and outside diameters, is that what your talking about?
bb429power
Post  Nevs on March 21st 2010, 3:59 pm
bb429power wrote:No, but I have the biggest micrometer they make. It goes to 3 inches, its the biggest I've seen. But I can take it to my machinists shop as he has the tools, I'm actually getting the crank through his friend. How could it be both? Inside and outside diameters, is that what your talking about?
They are stepped.
Calipers.
Post  fordman460 on March 21st 2010, 4:04 pm
The two different sizes are also different depths. 1.85 is shallow and the 1.35 is deeper. There are cranks with both 1.85 and 1.35. Also cranks with 1.85 and 1.25. The 1.25 is not a "true" pilot size but some companies sell converters for it.
By the way, outside mics get pretty darn big. I have a set up to 6" and I have seen one for 24"!
I hope you aren't pulling my leg with the biggest I've seen statement. Just trying to help!
fordman460
Post  the Coug on March 21st 2010, 4:16 pm
I have a set of 36" and I think there is a set of 48" here in the shop.... so not the biggest by any reach......
I am glad you found a stock Crank, not to be an A$$ but I know you will be happier and it more than likely will be in speck, I have a new Eagle forged and before I even think about it, it gets Major check out.......
Post  bb429power on March 21st 2010, 4:17 pm
fordman460 wrote:By the way, outside mics get pretty darn big. I have a set up to 6" and I have seen one for 24"!
Holy crap! I've never seen them that big! I will google it asap. I want to see what these monsters look like. You are helping, a lot. Thank you so much for helping me understand this, you and the other people who have helped. I learned some new things today, thank you very much.
bb429power
Post  bb429power on March 21st 2010, 4:23 pm
the Coug wrote:I am glad you found a stock Crank, not to be an A$$ but I know you will be happier and it more than likely will be in speck, I have a new Eagle forged and before I even think about it, it gets Major check out.......
Tisk tisk tisk, Eagle cranks are crap. You shouldn't use it since the stock crank is much better. Laughing I'm just pullin your leg. Thanks for the help, you weren't being a pain. One thing I'm wondering about is that I have Eagle rods and a crank in my 351w, are they good or not. I'm pretty sure they were taken to the crank shop through my builder. But is that bad that they are Eagle? Aren't there rods bad too?
bb429power
Post  the Coug on March 21st 2010, 4:30 pm
as long as it has been checked out and made sure it is right run the crap out of it..... Most of the problems with them are the bigger cranks the bore hole in the rod throws are ...... hmmmm thin from the inside to the bearing surface.... and have them checked to make sure the journals are round. I see no problem with the rods. I would run it if you have it allready together....
We were just trying to save you time and money cuz the Stock Crank is major strong.... I have a stock Crank stroked to 4" and been turning it 7400 for years and not a single problem, looks like new last time I saw it.....
Post  bb429power on March 21st 2010, 4:47 pm
You guys are probably getting tired of my endless pit of questions. But, did you mean run the crap out of the stock or eagle crank if it checks out okay? And how do you stoke a stock crank? Never heard of that. Suspect
bb429power
Post  Nevs on March 21st 2010, 4:54 pm
bb429power wrote:You guys are probably getting tired of my endless pit of questions. But, did you mean run the crap out of the stock or eagle crank if it checks out okay? And how do you stoke a stock crank? Never heard of that. Suspect
You offset grind the rod journals to BB Chevy dimensions. Been done for years and it works. We ran a 4.150" offset ground stock crank for several years, with zero issues. Used to be the cheap way to get more displacement before the aftermarket cranks became available.
Post  bb429power on March 21st 2010, 5:04 pm
Wouldn't that make the journals really small and weak? Wait, I get it now, but I question how strong they would be. But they can't be too weak if your turning 7200 rpm's.
bb429power
Post  Nevs on March 21st 2010, 5:08 pm
bb429power wrote:Wouldn't that make the journals really small and weak?
Not really. The rod journals are at 2.500" stock and by offset grinding can go to 2.200" with plenty of beef left. We were making 950 hp out of our A460 headed 514" combo, no issues as I said. This is why we are all stressing the stock crank, it's a great piece with a lot of potential.
