New built 472 BBF engine...REDUCED PRICE
Page 1 of 1 • Share •
I have a new professionally built 472 engine for sale, this engine was built for a customer who has now decided to go with a larger build. It is a damage free D9TE block, +.060", 3YAB crank @ .010"/.010", re-conn'ed D6VE rods with Speed Pro 535CP60 pistons (10.0 CR), plasma rings, Clevite rod, main & cam bearings, Mellings oil pump, screen & shaft, Comp XM270H hyd cam, lifters & chain set, new Ford Racing valve covers, front sump 6 qt oil pan, re-built D0VE-C heads with new valves, powder-coated Weiand 8012 Stealth 4v intake, new water pump, fuel pump, new billet HEI distributor & wires. Damper, hachet, pulleys & alt brackets included. NO carb, alternator, starter,flywheel or exhaust manifolds included. Engine has had a 3 hour break-in run & is still on the test stand for inspection, if desired. Full dyno workup is available for my cost ($400 per day + fuel/oil). This is NOT a race engine, but a VERY strong low-to-mid range torquer. 1200 to 5800 working range. I will mount on a metal stand for shipping. Possible help on delivery, DEPENDING on your location. REDUCED PRICE--$2500.00 OR $2150.00 MINUS the intake and the aluminum valve covers. Located in the Knoxville, TN area, zip 37804. Thanks, Rick...rbt3246(at)bellsouth.net
****** Due to several inquiries, the owner has agreed to sell the engine MINUS the intake manifold and/or the Ford Racing valve covers and/or the HEI distributor. I can install painted steel valve covers in lieu of the aluminum ones if desired, I do not have any regular distributors but I do have some factory cast iron 4v intakes if desired. Price would be adjusted accordingly.
fordloverracing- Posts: 21
