Race Engine Weights
Page 3 of 3 • Share •
Page 3 of 3 •
1, 2, 3
Re: Race Engine Weights
Hey Guys,
Fantastic! I can contribute too! LOL
My unmachined A96 weighs 160lbs
Jason
Jason
D-CEL- Posts: 6
What made that first engine comparatively lighter then the rest?
peganit2- Posts: 55
Talked to some chevy boys about that 600# number, and the 559 cubes. They were pretty quiet.
peganit2- Posts: 55
peganit2 wrote:What made that first engine comparatively lighter then the rest?
Answwer;
1. The block was a stock production block and it was lighter than the aftermarket blocks.
2. The alum. P-51 heads are fairly light in weight. They are an OEM style CJ head.
3. The FRPP Victor single plane intake manifold was lighter than the bigger A-460 or C-460 single planes.
4. The #1 engine that was weaighed was Bobby Shrewsberry's engine and he won Super Pro at the 2010 Ford bash with it.
Hope this helps,
Charlie
c.evans- Posts: 1507
c.evans wrote:peganit2 wrote:What made that first engine comparatively lighter then the rest?
Answwer;
Hope this helps,
Charlie
Not sure. The next lightest with p51's is +41#.
Any more reasons why #1 was that much lighter?
peganit2- Posts: 55
I would LOVE to get a BBF around 600lbs for my Fox Mustang, and I just want to know what it takes.
peganit2- Posts: 55
Engine #2, (Mike's) had P-51 heads, but the 41 lb. difference in engine weight can be attributed to the SVO A-460 block. That's Ford aftermarket racing block with really thick cylinder walls and siamese cylinders, also a beefier bottom end.
Charlie
Charlie
c.evans wrote:Engine #2, (Mike's) had P-51 heads, but the 41 lb. difference in engine weight can be attributed to the SVO A-460 block. That's Ford aftermarket racing block with really thick cylinder walls and siamese cylinders, also a beefier bottom end.
Charlie
Oh sorry missed that little detail.
Excellent information!
peganit2- Posts: 55
Have you ever weighed a 408 W ? With stock block.super victer intake.victer jr heads.ect?
I would like to know how much heavier the bbf would be thanks
2fox- Posts: 130
2fox wrote:Have you ever weighed a 408 W ? With stock block.super victer intake.victer jr heads.ect?
The published shipping weights of FRPP crate engines which also include the pallet:
392 "Z" engine = 545 pounds
521 with A460 block = 700 pounds
514 with production block = 670 pounds
rmcomprandy- Posts: 1882
565", A-460 block, A-460 heads, Crower/SVO 4.25" stroke crank ( 76 lbs) weight as seen 620 lbs. Weighed on two certified scales.
G
G-Code- Posts: 83
Page 3 of 3 •
1, 2, 3
Page 3 of 3
