chassis table??
138
Dave Maxwell
Re: chassis table??
Dave that table @ RadRides looks nice.
If we weren't 170 miles apart I would give you enough 6" C-channel to build a table out of.
The stuff is used but in good shape.
My employer gave me a bunch several years ago. We have built 3 car trailers and I still have a bunch more.
It's too nice to cut up for scrap but that may happen eventually.
mike
mike
f250mike- Posts : 628
Re: chassis table??
Doug Rahn wrote:I'm going to use "I" beams with slides that will lock in place with two jam bolts from the bottom.
The "H" & wide "I" beams do generally offer the greatest ability to C-clamp (or your slide clamp) stuff in place, next would be the C-channel laid flat like what mine is made of. But Dave's choice of 4x4 box tubing should work fine too since as mentioned most any material will work OK if the choice is to tack weld stuff in place on the jig vs clamping. It all can get the job done.
DILLIGASDAVE- Posts : 2262
Re: chassis table??
thanks for the offer of material. I will be making multiple clamps for the 4x4 that will have fixtures or clampiing tabs on them. Rubber backed plates for gripping power.
Dave Maxwell- Posts : 576
» chassis table??
» CNC Plasma Table -- table, plasma cutter, computer, software, ect
» Need some drill press table clamps...
» Future build round table
» 572 P-51 Pump Gas Street Engine
