EFI modifications
Page 2 of 2 Previous  1, 2
Re: EFI modifications
Post  schmitty on April 6th 2010, 2:37 pm
whatbumper wrote:why is that?^^^^^^^^^^
Different location of the manifold bolt holes.
Post  whatbumper on April 6th 2010, 3:32 pm
So, the intake bolt pattern is totally different? I am just trying to learn this stuff so take it easy.
I know small block stuff. That's why I am here is to learn the big block stuff.
Post  schmitty on April 6th 2010, 5:16 pm
Yes intake is different, and I believe the exhaust is raised and therefore different also. All early non EFI heads will interchange, but both versions of the EFI heads are on their own, E7TE and F3TE. I don't know that anyone has a method of adapting a carb manifold to the fuelie heads yet.
Post  95lightiningguy on April 6th 2010, 6:19 pm
schmitty wrote:Yes intake is different, and I believe the exhaust is raised and therefore different also. All early non EFI heads will interchange, but both versions of the EFI heads are on their own, E7TE and F3TE. I don't know that anyone has a method of adapting a carb manifold to the fuelie heads yet.
I have seen where someone, dont remember who, either sells or knows who sells adaptors on here or the other site.
95lightiningguy
Post  res0rli9 on April 6th 2010, 6:22 pm
I thank thats just an adaptor to put a carb on the efi intake
Post  mitch on April 6th 2010, 9:17 pm
Price motorsports makes an adapters to put a carb on the EFI intake, they also make an adapter to put a older carb intake on the EFI heads. what would be the advantages of doing this? could the EFI heads and intake with a carb make as much power as the old stuff?
http://www.pricemotorsport.com/
mitch
Post  whatbumper on April 6th 2010, 9:26 pm
You learn something new everyday.
If he has to run a cast iron intake what is the best one out there if he wanted to run a carbed combo? Also what kind of flow are guys getting out of cast iron exhaust manifolds.
Post  mitch on April 6th 2010, 10:05 pm
whatbumper wrote:You learn something new everyday.
If he has to run a cast iron intake what is the best one out there if he wanted to run a carbed combo? Also what kind of play are guys getting out of cast iron exhaust manifolds.
I think the top trucks in my class are 550+ hp
mitch
Post  plowboy34 on January 6th 2011, 8:19 pm
I have seen a couple of people use the 5.0 mass air ECU stuff somehow. Not sure exactly how they do it but it is OEM stuff.
plowboy34
Post  AK on January 10th 2011, 10:40 am
I would talk to someone from sct or similar and see if they could burn a chip for your specific upgrades.
AK
Post  old-n-sloow on February 4th 2011, 10:25 am
http://www.moates.net/
Look at the quarterhorse if you need to mod your ECM, it gives realtime output and allows you to change any setting instantly, while the engine is running. The basic unit is about $250, I don't know what other parts/software you'll need though.
old-n-sloow
