What tire pressures do you guys run
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: What tire pressures do you guys run
Bruno have you tried more pressure than that ? or does it lose traction going over 9.75 ?bruno wrote:28 x 10 w/ stiff side wall -- no tubes -- 9.75lbs @ 3200lbs
nuclearcobra- Posts: 969
Same here Melvyn once i got to 14psi it hooked the best and they wear even.514Fox87 wrote:3080lb 87 LX with me in it. MT 28x10.5 regular wall with tubes, 15x8 rim, Car 60fts at 1.39-1.40 with 13.75 to 14 lbs of air. Sounds like lot but the tires wear even and I started at 10psi and worked my way up and each time the 60ft numbers got better till I got past 14psi.
Page 2 of 2 •
1, 2
Page 2 of 2
