Need an MPFI manifold for 557 and turbo help
Post  Orcburner on May 1st 2010, 10:11 am
Hello,
I am at the beginning of my build. I have a 429 that I'm rebuilding. I'm puting a stroker kit in it to pump it up to 557ci. I'm going to use trick flow heads. 9.8:1 compression ratio. not totally sure on the cam yet, will have around .650" lift. my main question is this... There is a Holley Multi port fuel injection kit that I want to use, but it does not come with a intake or injectors. Anybody know of a good manifold for this setup and how many pounds should I go with on the injectors (was thinking like 60lbs).
Thanks.
in addition: I'm leaning towards a twin turbo system. from what I've read I think I'd go with around 8lb turbos. I'm new to the turbo world so not sure what type or size to go with and I could also use some help with what kind of waste gate setup to use. I know I have to use a cam with more seperation (if i remember correctly) and use copper head gaskets. any other tips or tricks would be greatly appreciated.
I contacted Turbokits.com and for what I want they suggested t3/t4 turbos and a pair of Tial 38mm external wastegates. anybody running this setup?
Orcburner
Re: Need an MPFI manifold for 557 and turbo help
Post  bruno on May 1st 2010, 10:25 am
welcome to the site ...... first question ...why the low compression ? and what is the application ?
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Post  Orcburner on May 1st 2010, 11:03 am
bruno wrote:welcome to the site ...... first question ...why the low compression ? and what is the application ?
This will be a weekend driver. you know blow off some steem by roasting the tires and haulin ass Smile I picked the 9.8 to make sure I could use pump gas to be honest.
Orcburner
Post  bruno on May 1st 2010, 11:29 am
here is a cool plug in program to figure injector size
http://www.rceng.com/technical.aspx
JET BOAT BOB
Post  Orcburner on May 1st 2010, 12:18 pm
bruno wrote:here is a cool plug in program to figure injector size
That's a great little program. But I'm not sure how much hp I'm gonna make. I've seen similar engines with Carbs around 725hp.
Orcburner
Post  t120r on May 1st 2010, 8:03 pm
If you're a DIYer, here's what I used:
http://www.rossmachineracing.com/dash10.html
http://cgi.ebay.com/ebaymotors/Universal-Fuel-Injector-Boss-Bungs-Holders-Cups-Qty-8-_W0QQcmdZViewItemQQhashZitem2eac8f9d1fQQitemZ200463588639QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/14mm-Injector-Drill-Tool-Bosch-Style-Inj-RMR-064-_W0QQcmdZViewItemQQhashZitem3caca23674QQitemZ260594349684QQptZMotorsQ5fAutomotiveQ5fTools
t120r
