how fast did you go with DOVE,C9VE,OR C9VE HEADS?
+7
Big block fox 339
342g
nuclearcobra
KY JELLY
Maddmattmustangs
11 posters
just like the title says DOVE,C8VE OR C9VE HEAD, im just wondering how quick anyones been N.A. @ 2900/3200lbs? no power adders .
how big is the engine? and @ what weight
1/4 MILE OR 1/8
thanks-RICH
1/4 MILE OR 1/8
thanks-RICH
BOSS 429- Posts : 2367
Re: how fast did you go with DOVE,C9VE,OR C9VE HEADS?
I personally havent BUT one of the best engine builders in the area has had a C9 headed ford push high 9's N/A in a 2900lb ish car. Wish i knew how he did it
my old 70 mustang went 6.21 1/8 with a 466 and dove c heads 2840lbs
KY JELLY- Posts : 1530
6.30 514 D2ve's 3200 lb.
I've been 10.57 @ 128.68 mph with a 1.48 60' at 2740 lbs in a 84 fox hatch its a 472'' with ported c8's with 2.19-1.72 valves and worn out single springs #926 for a 280 cam and the portmatch is way off with the 4150 victor intake,carb is a aed hp 950 i built from scratch with proform blocks and base plate with 76-86 jets the cam is a 292 comp flat hyd 244@.050-560 lift,trw 2404 pistons,c6 trans no brake and a tci 11'' converter that i cant footbrake over 1500 rpm.
nuclearcobra- BBF CONTRIBUTOR
6.11, 1/8th, 9.65 1/4, d-3ve-a2a heads, 2900 lb. cougar, grrrrrrrrrrr.
342g- BBF CONTRIBUTOR
wow these are all supper kool guys keep em comming
-rich
-rich
By the way, those heads are in need of a new home, very cheap, all they will need is a valve job, everything else is done.
I've messed with dove( c8,c9 ) a lot over the years ( bought my first pair in 1977) trying a lot of my own ideas and such, and was just wondering what some of your results were.
I have used them on 429s to 512ci engines ,just seing what you guys are doing
-thanks
-thanks
91 fox hatch full interior. Not sure of weight it's my first car still learnin to drive it I've only made about 10 passes
545 ci
234@ 50 hyd ft cam
doves very Lil port work if any 2.25 1.75 valves
10.8 to 1 cr on e85
950 carb
on 275 mt drag radials
Still ain't hooking but it went 7.08 @ 98 1/8
545 ci
234@ 50 hyd ft cam
10.8 to 1 cr on e85
950 carb
Big block fox 339- Posts : 279
what size carb? gear?
950 qft e85 out of the box
3:73 gear shifting at 5800
sounds like fun
My car with DOVE-C's has been a best so far of 6.201 @ 110.9mph. Its a 501, 14:1 cr, comp solid roller, victor intake and a 1050. Car weighs 3180 with me in it. I think with a cam change it will go faster. Motor has no low end and doesnt start really running until about a hundred foot out.
Race Ready Fabrications- Posts : 619
I just went a 6.03, 117m.p.h. at the bash, there is more in it, it was the first time out with the build.
My Mustang went 6.24 at 110MPH .The engine is a 472 flat top with DOVE-C heads and a roller. 4.86 gear with a 32" tire at 3045lbs. The engine went 6.00 at 115MPH in my Thunderbird
56Tbird- BBF CONTRIBUTOR
My old Maverick went 6.24 one cool nite. Same crank/rods/pistons thats in Harolds engine now on gas and C6 at #2970 w/DoveC's and TOO much timing.
My DOVE's went 10.50@125 1.36 60 foot 4000 lbs. 514 ci. Then they were put on a 2650 lbs. pro tube chassis car 552 ci. 8.73 @ 156 n/a and 7.83@183 with a fogger.
k.pascoe- Posts : 30
» how fast are you 545-557 Ci guys with dove heads
» Rebuilding a set of C9ve heads. Advice please
» Question on C9VE-A Heads
» Putting guide plates on my C9VE 429 heads.
