glide case
BIGDOG466
D. Sea
Page 1 of 2
Page 1 of 2 • 1, 2
glide case
i'm about to get a glide built for my junk and wanted everybodys opinion about which case to get.after reading some issues with the j/w i thought i'd ask.i'm going with a complete case type deal so what's your opinion? j/w.....reid.........ati.....etc. thanks
Re: glide case
What issues with the JW Case? Just wondering, I haven't heard about the JW issues?
D. Sea- Posts : 2768
Re: glide case
The reid is good stuff, you will need the case, bell and flywheeel to make it work. That set up is a little longer than a std glide, but since you are redoing it all coming from a 3 speed it wont matter. Dont skimp on internals............and you can usually buy one already done cheaper than it is to piece it together yourself.
Re: glide case
I like the JW stuff, I just had a issue with conveter clearence. My only advice is to get a converter made for a 1/8 or 3/16 thick mid-plate you can always shim the converter. JW tech is top notch to deal with. I like them because they re-sell well. X2 what Jon said about the internals!
BIGDOG466- Posts : 265
glide case
j/w problems i'v saw were with the bell on a sbc deal.it was a older one but the converter that fit fine before the stock bell broke would'nt fit after they put the j/w bell on it.most of this stuff is a "cut to fit"anyway i think,hell i had to put a .125 spacer between my case & bell on my c4 when i done the last converter swap and i ran it in a c6 before with no problems.i went to PTC today and they're building me a reid case promod glide.i'v looked and looked and all i could find was a used trans with a new price so i just went with them.i'm sure i'll see all kinds of good deals now,LOL thanks for the help
Re: glide case
I have the Reid/ Dedenbear one piece case with chevy bolt pattern for my dragster and never had any problems. You might price out the Case,Bell, and flex plate for your application. Then price out the complete one piece case and the ATI adapter kit with the flexplate. It may come out cheaper. Also if done that way I know you can use anybody converter if your ever in a predicament and you need a converter.
Ace
Ace
powerstrokeace- Posts : 1496
Re: glide case
the case i'm getting is a 2 piece with flywheel too.i dont know if the converter would be same as a gm or not.i have a tci flywheel now with both gm&ford patern and i'v ran them both.one converter i had was said to be a coan.it had c6 inside and a gm 3 bolt front side.i used a spline adapter in it and put it in my c4.the guy i got it from said it was in a bruno/lenco setup,it had clear fluid in it kinda like my wifes bmw.may a been hyd oil.powerstrokeace wrote:I have the Reid/ Dedenbear one piece case with chevy bolt pattern for my dragster and never had any problems. You might price out the Case,Bell, and flex plate for your application. Then price out the complete one piece case and the ATI adapter kit with the flexplate. It may come out cheaper. Also if done that way I know you can use anybody converter if your ever in a predicament and you need a converter.
Ace
Re: glide case
Reid cases sure are pretty. I have never had problems with any brand. Lucky I guess. We built this one for a pretty good price.
I have had this stock case glide for sale for a while and people keep low balling me. I tell them to try to build one for less. The gearset is $1100. 300m input shafts and modified pumps, the parts price add up in a hurry.
whatbumper- Posts : 3024
Re: glide case
The JW case/bell setup is what I use for non-GM builds. They've updated and improved the cases with each generation. Usually around $2500-ish to build a stock case Glide with a 1.80 gearset, good input shaft/pump combo, dual ring servo, pro brake, deep pan, etc. Add a bit more for the JW case if desired.
Oldani- Posts : 46
Re: glide case
Must be a slow day over on DRR for the trans-king to come visit us. LOL..
Thanks for keeping an eye on us over here Steve.
Curt- Posts : 2787
Re: glide case
Lol... I always forget to stop in here. Just thought I could harass Jon!
Oldani- Posts : 46
Re: glide case
Amen brother, I am glad to see some help with that!
Curt- Posts : 2787
Re: glide case
I can for sure handle what you two got to dish out.......and some lol.
So Steve, how is that 1 piece BTE case coming LONG? (f'in capslock)
Re: glide case
Slowly, lol. They're still getting things ramped up to produce them. The first incarnation will be a SBF/Glide from what I've been told. So you're hosed pal! Then I believe the Mopile/Glide is up next. After that I'm not sure but I've lobbied for the BBF/Glide to come out before they do the standard GM version. Which I believe should also have the BOP pattern on it. It's silly to produce a trans case for GM guys and only have it fit Chevy engines. Hey wait... I was nice to Jon... what's up with that... I'm supposed to harass him today since I'm here....
Oldani- Posts : 46
Re: glide case
Oldani wrote:Slowly, lol. They're still getting things ramped up to produce them. The first incarnation will be a SBF/Glide from what I've been told. So you're hosed pal! Then I believe the Mopile/Glide is up next. After that I'm not sure but I've lobbied for the BBF/Glide to come out before they do the standard GM version. Which I believe should also have the BOP pattern on it. It's silly to produce a trans case for GM guys and only have it fit Chevy engines. Hey wait... I was nice to Jon... what's up with that... I'm supposed to harass him today since I'm here....
Figures..........
I'll just have to Reid set up when I get ready................next fall.
Re: glide case
"Fall". I hate that word. After getting drilled with a cross-check right at the end of a hockey game on Jan 13th... I felt AND heard the snap and then I took a fall, lol. The end result of my surgery on Jan 15th :
Oldani- Posts : 46
Re: glide case
Thats what happens when you play non-American games.
Curt- Posts : 2787
Re: glide case
Well... at least some of my equipment came from north of the border, eh?
Oldani- Posts : 46
Re: glide case
Where's Pigley been posting at these days, bunch of lame shyt talkers here, I need need to see some real keyboard smack.
Re: glide case
Dunno... but his bud Rich wouldn't freshen his engine, lol. Per Rich.
Oldani- Posts : 46
Re: glide case
With you or without you, the very last thing we need here is a pigley. Thank you, not
We are all a least civilized to each other here since we share motor values.
Curt- Posts : 2787
Re: glide case
I enjoy watch Ed get his ass kicked on the internet. His threads ............well lets just say the procomp threads got nuthin on him lol.
Re: glide case
sorry, I wasn't including our foreign intruders.
Curt- Posts : 2787
Re: glide case
Lol. This site is pretty darn civil which is a nice change of pace from 'the other' place. And I halfway fit here as I did race this in the past and it had a 302 in it (not a blue one though...):
Oldani- Posts : 46
Page 1 of 2 • 1, 2
» Wanted good used
» TCI glide case
» Which c6 case should I get
» F apply or FF apply lever?
» REED ALUM GLIDE CASE
» TCI glide case
Page 1 of 2
