Well my Cam pin broke what kind should I get now??
Page 3 of 3 Previous  1, 2, 3
Re: Well my Cam pin broke what kind should I get now??
Post  cool40 on Tue Jul 27, 2010 8:07 pm
i have never used anything on the threads in a cam bolt.not a bad idea i guess,but you may need it out someday too. Smile
Post  bb429power on Tue Jul 27, 2010 8:10 pm
cool40 wrote:i have never used anything on the threads in a cam bolt.not a bad idea i guess,but you may need it out someday too. Smile
I know this because, well, you know Embarassed bolt walked right out on me and F'ed it up before the HS drags since we just replaced the cam. I've heard of it happening to other people too. Just throwing it out there.
bb429power
View user profile http://michiganmotorheads.forumjonction.com/
Post  cool40 on Tue Jul 27, 2010 9:59 pm
Big block fox 339 wrote:
dfree383 wrote:Put the cam gear on the cam and see if the snout of the cam sticks out beyond the gear.
I just put it on and it looks fine snout is inset
A engine builder built the engine he said he used locktight
I just ordered a arp cam bolt,c460 cam,lifters,and timing set from lem when everything gets in im gonna check piston to valve clearance to make sure nothing touching
did you have the fuel pump drive bolted on the cam gear?if it was make sure the tab that goes in the pin hole is not hitting the pin and holding it off the gear when you bolt it down.i'v saw it before when the cam pin was a little too long.hope you figure it out,let us know what you find.
Post  bb429power on Tue Jul 27, 2010 10:04 pm
That's what happened to me, the tab was put in the pin hole. Embarassed There didn't seem to be any other place for it to go.
bb429power
Post  nuclearcobra on Wed Jul 28, 2010 6:11 pm
You're right it go's in the pin hole but the pin cant be to long.
nuclearcobra
Post  Big block fox 339 on Wed Jul 28, 2010 9:18 pm
Thats possible il check that next time im at the shop
Big block fox 339
Post  Big block fox 339 on Thu Jul 29, 2010 7:47 pm
Looked over my short block today the intake valve reliefs has some slight markings in it is it possible I floated the valves I shift at 6000. I only over reved it once before I put a limiter in it. It was the first time I ever drove it I know it didn't get over 6700 rpm at the highest is it possible that it damaged the cam??
Big block fox 339
Post  cool40 on Thu Jul 29, 2010 10:01 pm
Big block fox 339 wrote:Looked over my short block today the intake valve reliefs has some slight markings in it is it possible I floated the valves I shift at 6000. I only over reved it once before I put a limiter in it. It was the first time I ever drove it I know it didn't get over 6700 rpm at the highest is it possible that it damaged the cam??
did you have any bent pushrods?
Post  Big block fox 339 on Thu Jul 29, 2010 10:05 pm
No they all seem straight just bent valves I'm using lunati 8.550 pushrods
Big block fox 339
Post  cool40 on Thu Jul 29, 2010 10:35 pm
i dont think the valve float woulda caused the pin to break.just check it all out good when you go back together and maybe it'll work out ok this time.it coulda just been a bad pin,i had the end of a crane cam break off in new build.it had the gear with the bolt and a big ass chunk of cam still in it layen in the timing cover,and some bent valves as you well know about.crane said i over torqued the bolt so i try to use a tq wrench and over torque it now.ioi.
Post  Big block fox 339 on Thu Jul 29, 2010 10:46 pm
Yeah I know about bent valves lol. I hope it won't happen again I'm starting over new and better
Big block fox 339
Post  WDR460 on Fri Jul 30, 2010 3:33 am
I hauled my cam bolt to 60ftlb and locktight. Single cam pin , Comp XR292R roller. This odd vibration developed a few runs later and snapped the fuel pump drive mandrel for the mechanical fuel injection in the middle of a run , and it coughed and died due to lack of fuel.
Further inspection showed chipped teath off the FMS roller timing chain in the sump on the drain magnet. OK , pulled the motor to have a look. Then I found the cam pin had sheared as well.
Looked and looked , then found the culprit. The cam washer , FMS fat good quality , had cupped and was not applying full clamp onto the timing gear face. Thus the gear moved around and this moving around was the sheared pin. Thank god the gear didnt move much and i did not suffer any valve damage. Drilled a new timing gear set and the old cam with twin pins fitted , bought an ARP Washer and bolt set . All fixed.
John
WDR460
Post  Big block fox 339 on Fri Aug 06, 2010 6:34 am
Ok the springs that were on my heads was for like over .700 lift so the were really week at my .565 lift so I'm pretty sure it was floating the valves not sure if that broke the pin
Is 6000 rpm to much on the hyd ft cam
Big block fox 339
Post  cool40 on Fri Aug 06, 2010 4:21 pm
confused .700 lift but were weak?
Post  Big block fox 339 on Fri Aug 06, 2010 5:37 pm
The springs were weak for my cam they were made for a bigger lift cam
Big block fox 339
