How to determine data from a torque converter?
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: How to determine data from a torque converter?
The converter clutch will lockup at cruise, so you won't have problems with cruise rpm being lower than the stall speed.
Greg
Greg
Greg_P- Posts: 1007
okay, i called the company that eventually sold the converter.
i got a lot of info, maybe someone can chime in and help me further o,.
To begin, it is a low stall speed, but an exact number wasn't there, it averaged approx. 1800 Rpm's.
The other data i got was:
Diameter: 12 inch
Input shaft: 31 splines
Hub style: flats
Hub diameter: 1.9965
Hub height: 2.312
pilot diameter: 1.375
Pilot length: 2.00
Mounting bolt radius: 5.700
Mounting style: 4 studs
And it has a lockup.
Anyone can tell more with these numbers?
I think 1800 Rpm's is good, right?
Seems a low stall to me.
And as mentioned before by someone, since it has a lockup, the cruise speed RPM's arn't really a problem being lower as the stall speed.
So, i guess i just going to try it under the car when the engine is ready
Thanks!
Diameter: 12 inch
Hub style: flats
Hub height: 2.312
Pilot length: 2.00
Thanks!
dutchie- Posts: 62
Page 2 of 2 •
1, 2
Page 2 of 2
