466 ranger build
466 ranger build
Post  kjett on June 3rd 2010, 9:42 pm
Been putting this off, but finally got time to post it up! Here's some of the specs for my little ranger mud truck build:
89 ranger standard cab long be body sitting on 78 F-150 shot bed frame.
D44 front/9" rear axles.
coilover/monoleaf rear suspension (to keep me in "must have leaf spring" suspension rules) on AFCO spring sliders and chromoly ladder bars.
custom rate coil springs and CE adjustable drag shocks
Coan prepped rollerized c6 with hardened input/output shafts, billet servo and clutch baskets, Alto clutches and kevlar band. Full manual reverse pattern valve body.
Stall is a 10" 3500 advertised converter, and will get reflashed after the dyno tune.
Now for the motor:
D1 block bored .030, hardblock filled to bottom of water holes, zero decked for rotating assembly
SCAT h-beam rods
SPR forged flat top pistons with 2 valve notches
Helfire moly rings file fit for the 250 shot of NOS that the truck will see Very Happy
Freelander ported and worked D0VE-C heads
Lem worked Comp solid roller cam 110lsa 268/277 @ .050 750/760 lift
Comp solid roller lifters
Crower SS roller rockers
Jomar stud Girdle
FRPP 4500 Victor intake
Holley 1150 Dominator
MSD dizzy fed from MSD 7al-2 ignition box
Schoenfield 2 1/8" upright headers
ARP head studs
ARP main studs
ARP 2000 rod bolts
Canton windage screen
Ford 370 truck 10qt oil pan with baffles added in.
With 9 qts of VR1 20w50 oil, priming the oil pump gave me 77lbs of oil pressure! Now to get it to the dyno for break in and a tune!
Some pics of the truck in my buddy;s driveway on 35" boggers:
And some of the motor as I was putting it together:
Last year with 39.5" cuts and the old motor:
So what ya think it'll make?
kjett
Re: 466 ranger build
Post  kjett on June 3rd 2010, 10:06 pm
forgot to add the head flow numbers:
.100 76/60
.200 159/113
.300 234/145
.400 290/167
.500 308/181
.600 321/186
.700 327/186
.750 .327/187
This was done on a Superflow flow bench at a certain shop in KY Very Happy
Plan is to pull these heads this fall and do more work on the ports for next year Wink
kjett
Post  BRONCOBILLY7.5 on June 4th 2010, 3:00 pm
I'll take a stab....690hp/610tq
BRONCOBILLY7.5
Post  dfree383 on June 4th 2010, 7:59 pm
Lookin good Karl
Post  windsor on June 5th 2010, 7:03 am
cheers
Let us know how she does!
Post  kjett on June 5th 2010, 4:40 pm
Thanks guys. I hope it does good! I's be happy with 690hp, but I know it won't make that. DD says 651 @ 6500, so if I get close to that, I'd be happy.
kjett
Post  dfree383 on June 24th 2010, 7:25 pm
Well ?????
Post  IcallhimGeorge on June 24th 2010, 7:36 pm
body looks crooked and the oil pan needs painting.
otherwise, I think it looks like sh!t.
IcallhimGeorge
Post  kjett on June 24th 2010, 7:56 pm
This traveling crap for my job makes it hard for me to keep dyno dates! It severlely sucks now since Carrol Carter is all booked up until the end of July. He recommended I contact a guy named Lee Edwards out of Calverton, VA. Said he's another Ford guy that used to work for him way back and has a new Superflow dyno. I believe he said it's a SF-902. So now to track him down and see when I can get in. Anybody know him or how to contact him?
I'm more upset that I couldn't get to dyno it over at C&C Persormance. It's a really small place, but the last time I was there I saw about 2 dozen of those nice aluminum blocks all stacked in the corner. To be honest, I walked out with a chubby. Very Happy
kjett
Post  IcallhimGeorge on June 29th 2010, 7:28 pm
Karl, you walked in chubby.
IcallhimGeorge
Post  kjett on June 29th 2010, 8:13 pm
IcallhimGeorge wrote:Karl, you walked in chubby.
True, but part of me got even chubbier looking at all that aluminum in the corner Very Happy
On another note, dropped the motor off today to get the once over before being put on the SF902 dyno this coming Saturday. Only problem is he only has BBC flanged headers. He does a bunch of big ci, aluminum headed motors for truck pull motors and wondered why I only had iron heads. After a bit of conversation, I explained that I have more fun whipping up on the aluminum headed motors with my old iron. Laughing
So the bad news is now I'm in a mad search for a set of SCJ flanged headers before this weekend. Mine are 2 1/8" uprights, so they are not usable for the tune session.
kjett
Post  IcallhimGeorge on June 30th 2010, 10:52 am
Ive got some cast iron manifolds Ill send you for that turd. Razz
IcallhimGeorge
Post  kjett on July 3rd 2010, 10:17 pm
Spent the day on "The Dream Killer" as Lee Edwards calls his dyno. Learned some things that will help me out later on, and had the huge sigh of relief when it fired right off fairly easily. Only made 6 real pulls all day, but made changes that we thought were the best. I can't believe how large the jets in the 1150 had to go to feed the thing, and only in the last pull was the air/fuel decent across the pull. Pull #5 made just a tick more hp, but had a fairly lean spot across the middle that we though would shorten the life of the motor quickly if my NOS tune was off.
Started out with 95/98 jets, rear jet extensions and .028 high speed air bleeds in 7320-1 1150 hp Dommy, no spacers, 34* total timing. Made a max of 594.6hp @ 6400 and 522.8tqe @ 5200. Air/Fuel was real lean across the middle, so time for a jet change.
For the second pull went to 99/100 jets all else the same. Maxed out at 610.7hp @ 6400 and 520.7tqe @ 5200. Still a little lean from the middle of the pull up, but doable.
Pull #3, added in the 1" Jomar Power Cone and put the NOS plate in that will live there. All else the same. Maxed out 617.8hp @ 6400 and 527.6tqe @ 5200. Got super lean of the top, need more rear jet!
Pull #4, put in a .138 jet in the rear (even though the jet extensions are probably acting as a restriction) and bumped timing to 35*. Maxed out at 622.3hp @ 6400 and 529.8tqe @ 5200. Air/Fuel is MUCH better now, time to squeze more power out of it!
Pull #5, Backed timing to 32*. Made 621.3 @ 6300 and 533.5 @5200. Got a wierd dip in the torque curve, going to change the high speed air bleed.
Pull #6, bumped timing to 33*, and went to .025 high speed air bleed. Gave the best air/fuel across the board! Wasn't too lean like the earlier pulls and was just about perfect, staying within .6 across the board and averaged 14.1. Maxed out at 619.1hp @ 6300 and 529.3 @ 5200. The wierd thing on this pull is the torque maxed out at 5200, dropped down to 522.7 @ 5700 then started climbing back up peaking again at 530.2 @ 6000. It was strange but left a fairly flat curve on the graph.
We left it there and they gave me suggestions to squeeze a few more hp out. 1st and foremost was the cloverleaf in the Victor intake. I left it in and just radiused around the pad to make sure the butterfly's were clear as well as smooth out around the turns into the runners. Lee said to pull the intake and cut that out as it was more than likely the cause of my torque dip when in combonation of the spacers. I can see his point as the cloverleaf does have the large squared off corners. For now, I'm going to get a 1/2" open spacer to put under the NOS plate just to make sure the spray doesn't land directly on the front and rear lands of the cloverleaf.
He also said something about why he calls his dyno "The Dream Killer." Something about when he had it set up he had them make it read lower than it should and if I took my motor as it sat over to Carol Carter's shop (which has his old SF 901) that it would probably bring the hp numbers up closer to 690-700hp. It made me feel better, but I'm still happy with the 620hp numbers considering it's only a 466 with d0ve heads!
edit: forgot to add, I had 73lbs oil pressure and 2000rpm and up. At idle it was around 45lbs. Good enough for me considering its a Melling HV pump with a pressure spring change.
kjett
Post  res0rli9 on July 4th 2010, 3:24 am
good numbers. I'd say thats a job wheel done Cool
Post  jc10000rpm on July 4th 2010, 7:14 am
did you end up with 99/front 138s/rear ???????????/
if your jet extensions are a restriction, why not fix it, usually (if everything is right) square jetting is close to right
jc10000rpm
