351 HO CLEVELAND
351 HO CLEVELAND
Post  BOSS 429 on Sat Jun 05, 2010 8:53 pm
FRESH INTAKE TO PAN
SCREW IN STUDS
CLOSED CHAMBER HEADS
4 BOLT BLOCK
.O30 OVER
NEVER FIRED
TORKER INTAKE FOR 4150 CARB
FRONT SUMP PAN
MELING PUMP
FEL - PRO
SVO
COMP CAMSWHAT?
EARLY 72 DAT CODE BLOCK HEADS
SOLID LIFTER CAM
MOTORSPORT
IM POSTING THIS FOR THE GUY I BUILT THE ENGINE FOR,
CALL BILL 815-419-1457
$6500.00 OR ?
__________________
-RICH
CIRCLE (R)
CHECK US OUT!!!
[url]http://racersforum.pro-forums.com
NEW FOR 2010
Unlimited DRAG RADIAL (DOT CLASS)
9.60 HEADS UP CLASS
10.60 HEADS UP "
11.60 HEADS UP "
12.60 HEADS UP "
11.99 TO 17.99 BRACKET CLASS[b]
FRESH INTAKE TO PAN
SCREW IN STUDS
4 BOLT BLOCK
.O30 OVER
NEVER FIRED
FRONT SUMP PAN
MELING PUMP
FEL - PRO
SVO
COMP CAMS
SOLID LIFTER CAM
MOTORSPORT
$6500.00 OR ?
__________________
-RICH
CIRCLE (R)
CHECK US OUT!!!
NEW FOR 2010
9.60 HEADS UP CLASS
10.60 HEADS UP "
11.60 HEADS UP "
12.60 HEADS UP "
11.99 TO 17.99 BRACKET CLASS[b][quote]
Re: 351 HO CLEVELAND
Post  Barney on Sat Jun 05, 2010 9:01 pm
Barney
View user profile http://www.hdraracingseries.com
Post  BOSS 429 on Sat Jun 05, 2010 9:05 pm
FRESH INTAKE TO PAN
SCREW IN STUDS
4 BOLT BLOCK
.O30 OVER
NEVER FIRED
FRONT SUMP PAN
MELING PUMP
FEL - PRO
SVO
COMP CAMS
SOLID LIFTER CAM
MOTORSPORT
$6500.00 OR ?
__________________
-RICH
CIRCLE (R)
CHECK US OUT!!!
NEW FOR 2010
9.60 HEADS UP CLASS
10.60 HEADS UP "
11.60 HEADS UP "
12.60 HEADS UP "
FRESH INTAKE TO PAN
SCREW IN STUDS
4 BOLT BLOCK
.O30 OVER
NEVER FIRED
FRONT SUMP PAN
MELING PUMP
FEL - PRO
SVO
COMP CAMS
SOLID LIFTER CAM
MOTORSPORT
$6500.00 OR ?
__________________
-RICH
CIRCLE (R)
CHECK US OUT!!!
NEW FOR 2010
9.60 HEADS UP CLASS
10.60 HEADS UP "
11.60 HEADS UP "
12.60 HEADS UP "
Post  BOSS 429 on Sat Jun 05, 2010 9:10 pm
IM TRYIN TO POST IT, NOT SHOWING UP?
FRESH INTAKE TO PAN
SCREW IN STUDS
4 BOLT BLOCK
.O30 OVER
NEVER FIRED
FRONT SUMP PAN
MELING PUMP
FEL - PRO
SVO
COMP CAMS
SOLID LIFTER CAM
MOTORSPORT
$6500.00 OR ?
__________________
-RICH
CIRCLE (R)
CHECK US OUT!!!
NEW FOR 2010
9.60 HEADS UP CLASS
10.60 HEADS UP "
11.60 HEADS UP "
12.60 HEADS UP "
Post  BOSS 429 on Sat Jun 05, 2010 9:23 pm
FRESH INTAKE TO PAN
SCREW IN STUDS
4 BOLT
.030 OVER
NEVER FIRED
FRONT SUMP PAN
MELLING PUMP
FEL-PRO
SVO
COMP CAMS
EARLY 72 DATE CODE BLOCK HEADS
SOLID LIFTER CAM
MOTORSPORT
$6500.00 OR ?
_________________________________
-RICH
CIRCLE (R)
CHECK US OUT!!
HTTP://RACERSFORUM.PRO-FORUMS.COM
NEW FOR 2010
UNLIMITED DRAG RADIAL (DOT CLASS)
8.60 HEADS UP CLASS
9.60 HEADS UP CLASS
10.60 HEADS UP
11.60 HEADS UP
12.60 HEADS UP
Post  BOSS 429 on Wed Jun 09, 2010 11:15 pm
yes had problems posting first page post,
bump
Post  BOSS 429 on Thu Jul 01, 2010 1:00 pm
bump
