P-51 headed 472 build... DYNOED
Page 1 of 3 • Share •
Page 1 of 3 • 1, 2, 3
Finished assembling my short block last night.
Thanks to Lem for the speedy service for my Diamond pistons, rings, Kaase oil pump, P-51 heads and Cometic gaskets.
All sent via USPS... 8 days from Kentucky to Calgary and the heads missed customs so no handling fees or taxes
Thanks to Ron at Custom Balancing in Balzac Alberta for balancing, piston pin and bearing clearances, and file fitting my rings.
Just have to get my cam degreed.
Ranch71460- Posts: 195
Re: P-51 headed 472 build... DYNOED
Nice looking Engine
Lem Evans wrote:
X2
Welcome to the P-51 family!!
D's557BBF- Posts: 963
Thanks guys. Lem, how much torque do I use to install the rocker studs?
65 lbs ft
Lem Evans- Posts: 4073
Good deal Ken. Steppin' it up a notch I see.!
Doug...
Doug...
ThndrChkn- Posts: 1792
Thanks Gents
Sooo... ever take one step forward and 2 steps back
After I bolted the pan on last night I rotated the crank and it stopped with a thud
The culprit, a rib on the back of the Kaase pump hitting the front crank c'weight:
Nothing a die grinder couln't fix:
Got the heads torqued on... resting my arms now
I noticed there were no piston valve cut outs for the exhaust valves. Is this normal with P51 heads? What v/p clearance did you have?
Larry Williams- Posts: 469
I had the plasticene rolled into 1/4" ropes and the valves barely marked it.
Larry Williams wrote:I noticed there were no piston valve cut outs for the exhaust valves. Is this normal with P51 heads? What v/p clearance did you have?
That's normal, no exhaust reliefs needed.
Nevs- BBF CONTRIBUTOR
Ranch71460 wrote:Thanks Gents![]()
Sooo... ever take one step forward and 2 steps back![]()
After I bolted the pan on last night I rotated the crank and it stopped with a thud![]()
YEP! It's not a big deal, but I would think as many that have to modified (all that I know of) they would make a "slight" alteration in the casting. Like I said though, it's not a big deal to just grind it off.
Doug...
D... Am I now an official member
I'll have to change my sig
Ranch71460 wrote:D... Am I now an official member![]()
I'll have to change my sig![]()
I'd say you are officially qualified!....
Page 1 of 3
