Cage, dash and wiring to go, finaly its almost done
Page 6 of 6 Previous  1, 2, 3, 4, 5, 6
Re: Cage, dash and wiring to go, finaly its almost done
Post  f250mike on February 3rd 2012, 11:13 pm
I can't wait to see what the 472 does at the track!!
My engine setup is real close to the same. Except it's in a 4000lb pig Crying or Very sad
Good luck with both builds
mike
f250mike
Steering shaft
Post  nuclearcobra on February 21st 2012, 12:40 pm
Had to make a new one because the flaming river u joint didn't fit between the header tubes.
nuclearcobra
evac tubes and seat brackets
Post  nuclearcobra on February 21st 2012, 12:43 pm
Welded in the evac tubes and made up some seat brackets.
nuclearcobra
Finished radiator and trans cooler mount
Post  nuclearcobra on March 17th 2012, 7:41 am
nuclearcobra
finished pipes with dynomax ultra flo's and driveshaft with loop installed
Post  nuclearcobra on March 17th 2012, 7:47 am
nuclearcobra
Finished welding the subframes in
Post  nuclearcobra on March 17th 2012, 8:01 am
nuclearcobra
Post  bruno on March 17th 2012, 8:35 am
looks great ......
THXS TO ALL MY SPONSORS
www.evansracingengines.com
JET BOAT BOB
Well maybe almost
Post  nuclearcobra on May 13th 2012, 11:35 am
While i was grinding for the bars that go into the hatchback, i found out that the guy that my buddy took his car to for paint,had cut out the spare tirewell and covered it with a piece of metal Shocked well what he did is put a piece of 3/16 plate over the hole and then used some 4'' wide strips to fill in the sides and front because his plate wasen't big enough,well he tried to weld it all toghether with a stickwelder i think that was way too hot, once he destroyed it all and figured he screwed up so now he covered the whole thing with a boat load of fiberglass so my buddy could'nt tell Evil or Very Mad what a mess Mad
nuclearcobra
Post  dfree383 on May 13th 2012, 11:41 am
Well...... good opertunity to take some weight out and do it right
