750hp turbo build
Page 2 of 2 Previous  1, 2
Re: 750hp turbo build
Post  whatbumper on June 30th 2010, 10:43 pm
schmiddy wrote:
Well unfortunately it's your typical Banks draw thru sytem w single holley 850, has anyone ever converted one of these to blow thru? I've thought about it, just need an aftermarket intercooler.
Also, i'd still like to run 1 carb, how much HP can a holley 850 dp support? What's the difference bt say a 1050 holley and the CS or CSU?
FYI, don't really like the demon, maybe it's just me not being used to it
I have seen over 2000hp with a 4150 carb in a blow through app. Your combo is NOT going to run out of carb with the setup you have in mind with an 850. To convert the banks system you can just get a carb bonnet from New Era Racecraft or one of the carb companies we have listed and build some new tubing to fit. You could run an intercooler but with the boost levels you are talking about and a pretty mild horsepower goal, I think you could save yourself some fabrication work and run it without one. And the C&S and CSU carbs are built for this type of app. That is why we recommended them over the plain holley. They might even be able to just modify your current carb.
